Results 14 to 26 of 27
    Mar 2006
    Good idea, but asking as part of my proposal that I have the property management company unlock that utility closet....too much to ask. period.
    What I don't look forward to is having to have a GC make the hole thru the deck and then a roofer afterwards....all proposed to the Association.
    Not to mention my time setting that up.
    My upper unit really needs AC tho.
    It's an 887 sq ft. condo that is situated above 2 garages (one my own). Heat rises.
    Feb 2007
    Quote Originally Posted by caslon View Post
    I agree with smokin. The whole installation would go a lot easier, and there would be a lot less tubing bends.
    I'm not buying the utility closet door excuse. The door is already open in the one photo. Even if you had a hard time getting the door unlocked, it would be a lot easier than going through all the other BS.
    Near Chicago, IL
    There might be fire code issues going through the mechanical room. Better check into that.
    Mar 2006
    Quote Originally Posted by neophytes serendipity View Post
    You need one of these: http://www.rpscurbs.com/alumiflash.htm
    Cut the deck and install one of those flashings. Use round or flat head fasteners, not something with a protruding hex head. Call a roofer (or trade the condo association approves) to make the flashing water tight to the deck.
    Do yourself a favor and cut one big hole under the flashing- not a few little ones.
    If the deck is concrete, call a coring company with a coring machine that has a vacuum anchor base.
    Keep the flashing far enough from the wall to make connections. Make the hole in the wall high enough to work with the flashing. If the lineset is small enough, you might be able to feed it through without a joint... but keep future service in mind.
    The rubber top of the flashing will enable a water tight connection to the things passing through it.
    Ok. You're telling me to call a roofer and have it done before I've even proposed my plan to my condo association. Please, get real.
    You idea has total merit, but little real help.
    The idea of going thru that maintanence room, lol, gimme a break there also.
    "Hello, maintanence company of my condo, come and unlock that door."
    "You'd better be here on time." (all part of my proposal to the Association).
    No guys...my best bet is to treat my upper deck as if it puddled up water at that corner, and I want a drain hole put in there. Then, present that well thought out plan to the Condo Association, have it approved as part I phase.
    Phase II is a piece of cake. The AC company installs line thru a sealed approved "drain hole" cut into deck.
    Funny how I have to ask and answer my own questions here.
    Finding a GC who will do it and that I can present to the Association is another thing. It's not money in his pocket to do such a small job.
    I found one that is willing to talk to me about it.
    But come on guys...going thru a maintaince room?
    If this were my own property, I have the tools to do it. It's dealing with the damn Association. All your ideas would be valid then.
    "I have this deck that puddles water in the corner." I want a 4" hole cut thru a non-slab deck".
    Wish me luck lending a GC to my proposal to the Association that won't cost me $400+
    Hehe, I just want a drain hole cut in my deck, and waterproofed. Maybe not $400.
    Hell, time is money for a GC, no matter if it's a drain hole cut in a 6" thick non slab deck.
    Lancaster PA
    Your forgeting that not every contractor has had to deal with a condo or HOA.
    Mar 2006
    So true.
    My condo wasn't plumbed for AC like the rest of the units that were.
    It's an upper story end unit. All upper floor plan. A big rectangle.
    Above my garage and anothers. It's quiet.
    What's cool is that the Condo Association doesn't mind my using the
    space under my stairwell for the AC.
    They turned down my proposal with concern about a hole thru a not slab deck.
    They apparently are worried about the 4 inch cut hole thru the deck, rightfully so.
    So forget going into the utility room. While feasible, who thought up that rediculous idea?
    That's just dandy. How do I submit a proposal that includes unlocking a door to that utility room, lol
    Which one of you thought up that idea?
    I'm a 30 yr state licenced painting contractor, think before you talk.
    Florida
    So true.
    Stick to painting. If you're too scared about a condo HOA to submit a real proposal which includes unlocking a friggen door with plans for a lineset that looks professional and will not harm any other condo's value(the HOA's main concern with this), THEN YOU GET REAL. Have johnny half a$$ chop a hole in the deck and put a drain there. You asked a question, got good responses, and turned into a a$$clown with your replies. Good luck, you'll need it.
    Near Chicago, IL
    Actually, I thought the short paragraph I wrote up was pretty clear. I did not tell you to call the roofer and have it done right away, all I did was provide a link to a product that will solve your waterproofing problem.
    The flashing gives the roofer something to waterproof, and unless you will have more than 4" of standing water there won't be any problems. Flashing the opening prevents water damage to the deck (concrete or wood), something your "drain hole" won't do.
    In the Chicago area, there is no problem finding roofers or coring companies to do patchwork or a single cut. Both tasks will be over $400 by the time it is done, though. They charge by the hour, and there is usually a minimum of 4 hours.
    No one will do that work for $50. Will you drive to a job, tie up about half of your day and not charge for it? Unless you do a job at your neighbors house and walk there, you will have a minimum of 2 hours total time invested including: drive time, set up time, actual work and then cleanup.
    Odds are, you will not be able to go through the mechanical room due to fire code issues.
    Your proposed job isn't that difficult. You may be a painter with 30 years experience, but you obviously don't know squat about a retrofit HVAC job and what it takes to do the job professionally.
    Why not ask the association for a solution? I bet they have an approved roofer and carpenter contractor.
    Ct
    So true.
    That would be me jackass. The real reason they turned you down is because the proposal you offered them probably looked like some weekend warrior home depot hack drew it up.(Oh wait, one did.) OF COURSE they aren't going to let you chop up they're property with some half ass crazy idea like the one you have. Cut a drain into the deck, seal it up, and stick a friggin lineset thru it, lmfao. I got news for you, most states won't allow it anyway. You came onto a forum loaded with pro's with cumulative centuries of experience, ask a question, get proper responses, then have the balls to criticize the results!
    Take a walk.
    The bob vila DIY hacker forum is calling you.
    Dallas & Longview, TX
    Another vote for the mechanical room. It takes more time to drain the water heater than it takes to disconnect it. Going through the deck will look like a hack job.
    Mar 2006
    Quote Originally Posted by smokin68 View Post
    Stick to painting. If you're too scared about a condo HOA to submit a real proposal which includes unlocking a friggen door .
    Hahaha! What? Submit a proposal to a fairly cool condo association that requires them to unlock a door.
    I'm thinking exactly how I word that... (approve my plans that includes having our maintainence company show up at the exact time the installers are here, 5 weeks from now).
    Piece of cake, no hassles. Right, lol. "We'll be right over and unlock that door..." heh.
    This is a 212 unit complex, not 7 condos. Our maintanence company handles 2000 units and their main office is a modern 3 story office complex.
    My idea is to just handle this as if I have a puddle on that area of the deck and get that "drain hole" approved.
    Son of ***** is...getting someone to do it (yellow pages). I have some feelers out.
    A roofer/GC is my best bet, considering that just a roofer may not know jack about the support beams, where to cut. I don't mind if the hole has to be further away from the wall, the HOA won't fuss if let them know how I will cover it (cosmetically speaking). It's better than a big ugly compressor on a nice clean deck.
    I have a very good AC company to install it.
    ASI Hastings Co. here in San Diego. The other AC companies who bid on this were buffoons.
    Near Chicago, IL
    ...A roofer/GC is my best bet, considering that just a roofer may not know jack about the support beams, where to cut. I don't mind if the hole has to be further away from the wall, the HOA won't fuss if let them know how I will cover it (cosmetically speaking). It's better than a big ugly compressor on a nice clean deck.
    I would bet that a roofer would know what is safe to cut, and what isn't.
    Putting the condensing unit on the deck is no less ugly than the linesets and electrical service sticking up through the deck surface. It is also an easier solution.
    Mar 2006
    A butt ugly solution which should drop my condo sale price down some, when I sell.
