Results 1 to 7 of 7
    Nov 2007
    walnutport, pa
    Red face equipement advise
    New to the service and commissioning of residential/light commercial industry and am looking to purchase evac,vac pump, gauges, micron gauges etc. Looking for any direction. I'm hoping to get guidence on what brands , good or bad, I should consider and what to stay away from.
    weber's Avatar
    weber is offline Professional Member/Membership Committee
    Southern Ca, Elkton Md
    I recommend the Yellow Jacket brand.
    Invest wisely, good tools are not cheap but well worth it.
    In this industry you are judged by the tools you utilize, so be professional.
    I would recommend staying away from CPS, and UEI
    "Correct Installation is the Key"
    .1 has killed more HX then Rush Limbaugh
    What is your TESP?
    Nov 2007
    walnutport, pa
    yellow jacket is a brand you can trust but do they have different grades of equipement? Say i was to concentrate on residential- what size vac pump should i consider? 1.5 or 4. i have heard differing opions.
    weber's Avatar
    Quote Originally Posted by dh1052002 View Post
    I use the YJ 1.5 pump and highly recommend it.
    It depends on what you are buying, some products have higher end models that have more bells and whistles, but for the most part you cant go wrong with thier products.
    What is your TESP?
    INDIANA
    I use a supco micron gauge.
    As for gauges i prefer y/j
    Madison, Wisconsin
    Imperial flair kit, and tube cutters.
    Fluke
    Klein wire stripers
    Malco nut drivers
    I like my 6cfm YJ pump
    D Tek sniffer
    Takes time to build a good set of tools that you like. So don't rush it.
    Have fun with the new toys
    I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
    Nov 2007
    walnutport, pa
    Confused
    I found a yellow jacket R60 recovery unit used but in exellent condition.is it worth looking at?
