Results 14 to 21 of 21
    Florida
    Red face Residential A/C
    This problem you are having is what I call a very simple process of elimination, one step at a time and you will eventuallly step into a hole. Hopefully its a very small hole. Good luck.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by powerup View Post
    uhh, what?
    Myrtle Beach, SC
    Sounds like low air flow.
    Caused by restrictive air filter, dirty filter, dirty blower, no filter( Causing dirty coil), closed registers, damaged ducts, etc.
    Remember, Air Conditioning begins with AIR.
    Valdosta Ga
    Cool
    Ditto on low air flow dirty coil or filter
    Apr 2004
    First thing is first, is it matched?
    Nov 2007
    walnutport, pa
    outdoor txv is not operating
    Grottoes VA
    If the txv is not operating you would not have a 70 suction.
    Myrtle Beach, SC
    If the Outdoor TXV was not operating, you would not have high head either. If the outdoor check valve was stuck open, you would have high suction and low head.
    Poor heat transfer at the condensor coil (Indoor coil in heat) is the only likely answer besides over charge or non condensibles. And poor heat transfer would normally be caused by low air flow.
