Results 1 to 13 of 21
    Nov 2007
    walnutport, pa
    rheem heat pump troubleshooting
    I have a Rheem heat pump that is tripping on high limit sensor. When gauges are hooked up low side is steady at about 70psi while the high side starts at 100psi and continually increases to 400psi when the high limit trips. This process takes less than 5 min. This is in heat mode. In cooling mode the pressures equalize and stay constant around 95psi. Any ideas are welcome.
    S.E. Pa
    Lost?
    Uh, the HVAC troubleshooting forums are north of here.
    Admin.--Forum change?
    Thx,
    Hearthman
    NW AR
    Elementary. I have almost no doubt your a DIYer, which is fine, but we cant give tech advice to you.
    Valdosta Ga
    I can't say might be a restriction
    Quote Originally Posted by hearthman View Post
    Thx,
    Hearthman
    too few posts for pro enrty. chances are its over charged. rheem, ruuds (cruds) are sensitive to charge in heating and always run very high head pressures!! heating and cooling. may also be restriction. but am willing to bet thats its over charged
    Nov 2007
    walnutport, pa
    thanks for the replies. Not quite a diyer, I've been stuck in the com install side of the business for 12 years. I am trying to broaden the horizen by learning the service end of our business. Sounds like my problem would be an obstruction or could it be the reversing valve. this unit has been in service since 2005 with no issues so i am ruling out the overcharged theory.
    Oct 2002
    Florida Panhandle
    Airflow problem, check coil and blower for dirt.
    Roy
    A man is no less a slave because he is allowed to choose a new master once in a term of years.
    Lysander Spooner
    weber's Avatar
    weber is online now Professional Member/Membership Committee
    Southern Ca, Elkton Md
    No, DIY help in this forum.
    As a homeowner you should check your filter, and then call a hvac contractor.
    "Correct Installation is the Key"
    .1 has killed more HX then Rush Limbaugh
    What is your TESP?
    Oct 2002
    Florida Panhandle
    Quote Originally Posted by dh1052002 View Post
    How about sticking something in your profile, so we at least can tell.
    Roy
    Lysander Spooner
    Grottoes VA
    airflow or overcharge
    Nothing wrong with wanting to expand your knowledge.
    You should get one of the service techs to help you on this.
    Post your obsevations, and what it was.
    Get your post count up. Then you can apply frompro membership, and get access to the pro forum where we can answer questions.
    florida
    problem
    you have a problem befor you blow that compressor call a pro
    Valdosta Ga
    Like control boards don't see too much trouble with reversing valve but thats a good guess There would be other thing more likely to cause this problem
