Results 1 to 13 of 14
Thread: chimney liner
    Apr 2005
    new jersey
    chimney liner
    I will be replacing a very old gas furnace with a 90% furnace venting out the sidewall. I will be capping off the 5" hole at the masonary chimney.should there be any concerns with the hot water heater continue useing the exsisting chimney? should I automaticly need a chimney liner for the hot water heater or be ok. I allways assumed it would be fine.
    burlington county n.j.
    if chimney goes up outside wall it will need a liner to pass inspection.
    SE Michigan
    You need a liner kit, especially if the chimney is exposed on three sides or in other words, an exterior chimney.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Mississauga
    Thats code up here, you'll need a liner.
    Wink
    Quote Originally Posted by seanc View Post
    yup it sound like general venting rule to me so it need to be according to venting table in the code and not every one can READ THOSE CHART so make sure you consult on this one
    sorry i will look it up for you Monday i don't ave mi code with me ? What is your lateral length and chimney height and also BTU/H flue outlet size also
    MN
    how olds the water heater? If it's close to old enough for replacement, save some ching and get a powervent water heater installed now too. sorry missed you were pro, sell em a w.h. too
    You can't fix stupid
    Feb 2007
    There won't be enough heat to keep the chimney dry, and there won't be enough draw to get the flue gases out, especially in the summer. The chimney will start to fall apart. I've seen tile lined chimneys fall down inside and block the chimney base. You definitely need a liner, or do what cmaj said, install a high efficiency water heater. Not worth someone's life.
    PA/DE area
    Liner a MUST in PA/DE some guys do not pull permits and I can see the vent out the side of the home ,but NO liner out the stack. SAD!!!
    It's NOT the BRAND,it's the company that installs it!!!!!
    Nov 2000
    Eastern PA
    Without a chimney liner the water heater will rust out prematurely, sometimes within one winter.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    northnewjersey
    I Have Similar Situation But My Chimney Already Has A 6" Liner Stainless Steel Would I Need To Go With Smaller Liner.house Is 1 1/2 Story Cape With Cap.
    Feb 2007
    Quote Originally Posted by JOEDIESEL View Post
    You need to know what your net stack and draft is. The company installing your 90+ furnace should be able to tell you if everything is ok.
    Nov 2000
    Eastern PA
    Figuring on about a 35K Btu water heater into a 6" metallic chimney approximately 16' high, I'd say you should have a 4" liner dropped into it.
    The problem is that with that much open space in the 6" chimney, during the winter months the chimney is going to remain cooler then the dewpoint of the water heater's flue gases. When this occurs, acidic condensate forms and drains down the piping into the water heater. The smaller sized liner allows the flue gases to stay warmer (above dew point) to allow the flue gases to exit the termination point of the chimney to the atmosphere.
    Jul 2000
    Northern Wisconsin
    There are venting requirements for every fuel burning piece of equipment. Most every local in the country is under some form of code and most local codes refer to venting codes in one form or another. Sometimes they just do a blanket statement of "installation must conform to manufacturers recommendations".
    So...... short of saying yes you need a liner...... I'd be willing to bet you will.
