Results 1 to 13 of 16
Thread: Cam Stat
    Ohio
    Cam Stat
    Having hard time finding the combination limit and time start fan cam stat, my supplier says there on back order and not sure when they will be able to get them. They said that the company that they get them from is going out of business, is any one else having this problem? And if so is there a good replacement part because these cam stats are junk.
    I was thinking just putting in the honeywell fan limit control and just doing away with the cam stat,what do u guys think? thank for your input.
    Massachusetts
    This question belongs in the pro area. Why aren't you a pro member?
    Dec 2006
    Middle Tennessee
    ya, and fill out your profile
    or we will just consider you joe diy'er
    Suppy NC
    Jognstone or RE. MIcheals should have them
    as far as i know they only sell to contractors/
    Illinois
    Kato...
    Based on a brief glance of your posting history it is obvious you need to apply for pro membership. The answers you seek can't be given in the open forums.
    Ohio
    Wink sorry skip and air
    I once was on this site all the time but as i got busier i have not been on here as much but i will try and do the profile to save any ?
    Ohio
    Smile
    Quote Originally Posted by Senior Tech View Post
    Kato...
    What do I need to do to get the pro membership status?
    Houston,Tx.
    Cam Stat?? How old is that Furnace?
    __________________________________________________ __________________________________________________ _________
    "The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth".
    Ohio
    About 25 yr old lennox but the problems is that they are in a apart complex of about 100 and they all have them. Tring to get the furnaces changed out but tipical landlord why change them when they are still working. Explanded to them that 1 day you will be changing a few in 1 yr so why not do 1 a yr to get start the process. We will see that was the answer 3 yrs ago.
    Feb 2007
    Try Sid Harvey. Ask for Watsco - Cam-Stat. If they have them, it will probably be remanufactured and you have to give them your old one.
    Quote Originally Posted by katohvac View Post
    A lot of those old Lennox units already have extra mounting holes drilled that match a Honeywell fan/limit control.
    I'm guessing it is a 7" insertion CamStat, so you would need an 8" Honeywell.
    Been down that road a couple of times myself.
    Illinois
    Apply here
    http://hvac-talk.com/vbb/showthread.php?threadid=116113
    Suppy NC
    i believe the honeywell limit is now the lennox replacement if you order it
