Results 1 to 13 of 31
Thread: Testo 510 users
    Jan 2006
    Powell River, BC, Canada
    Testo 510 users
    Just recieved my new testo 510 manometer. Woo hoo! New toys! I was suprised with the size/weight of the unit. It looked bigger in the pics.
    Is there a maximum length allowed for the tubing used? Can't find any mention in the destructions. Any tips/tricks with using this baby? Is the accuracy good for measuring duct static pressures? Can't wait to try her out!
    Where are you? Are you done yet? I got ONE more call for you.....
    Jun 2001
    Louisville, KY
    Turn it ON before connecting to system. It zeros on startup.
    Don't turn it upside down while measuring. It will change your reading.
    Yes, I love my 510. Great tool!
    If we stocked them, I'd sell one every time I used it on a service call with a tech.
    Merry Christmas
    Jun 2001
    Louisville, KY
    If you don't already have them, get some 1/4" barbed tees and some extra lengths of tubing so you can T into the furnace pressure switches.
    Merry Christmas
    Jan 2006
    Quote Originally Posted by jrbenny View Post
    That's already on the list. Also wated it for pd through carrier 90% furnaces. Part of their new inspection routine for hx failures. The more I think about it the more handy this thing will be!
    Jan 2005
    Akron
    There is no max length on the tubing, however, a longer tube will give you a more stable reading due to the dampening of the signal. The 510 also works very well with a pitot tube for measuring airflow and has adjustable air density for accurate measurement and a timed traverse mode.
    The cover can also be installed on the bottom of the meter when you are using it.
    The 510 incorporates a temperature compensated sensor so the meter will remain very stable. For highly accurate readings, the 510 should be kept in the same position for the measurement that it is zeroed in. Most of the time I just attach it to the duct via the magnet on the back of the instrument the zero the sensor. The long term stability is excellent.
    JLB- Co Owner TruTech Tools Inc.
    Springfield Mo
    As a student new to the industry I've been trying to figure out which tools I'm going to need. I was looking at the 510 but was wondering If I can use it to check gas pressures (natural/LP). It is described as a differential manometer.
    Jun 2006
    Where do you get the 1/4" barb tees?went to Ace,homedepot,lowe's,supply house none of them have it,well homedopot got the 3/8" but not 1/4". i been looking for this for awhile.
    Feb 2005
    Miami, Fl.
    Quote Originally Posted by fishunterhvac View Post
    Aquarium store..
    Jun 2001
    Louisville, KY
    Quote Originally Posted by cib11mike View Post
    Yes. It will work great for you!
    Most 90% gas valves are enclosed combustion. The gas valve references burner box pressure instead of atmospheric. So, you need to have differential ability when checking outlet gas pressure.
    Merry Christmas
    Jun 2001
    Louisville, KY
    Quote Originally Posted by arpa View Post
    Aquarium store..
    or Trane Parts. The Louisville store used to have them on the shelf. It's been a few years, but that's where I bought mine.
    Also, any supply house that services the pneumatic controls industry.
    Merry Christmas
    Mn the state where absolutey nothing is allowed
    graingers
    Central NJ Area
    A quick question. On a 90% furnace with a enclosed burner box. You must use a differential manometer to adjust outlet pressure? If so, do you just T in somewhere between the burner box and pressure switch?
    you can use a single port manometer if you take the burner cover off...
    or just pull the hose off the gas valve. remember your manometer must reference the same pressure zone as the air side of the gas valves internal regulator
