    Nov 2002
    NJ - WORK IN NYC AREA
    Wr Gas Valve 36d13-208
    Hi Guys,
    need help.
    Have a 20 yera old REZNOR in line furnace with no name plate.
    The original gas valve failed: WHITE RODGERS 36D13-208
    Tried all over NYC today even reznor no help since we don't have M# of furnace.
    I punched in the WR number on the rodgers site and the following info came up:
    Suggested replacement : NONE
    Valve description:
    24 VOLTS TWO STAGE with Sol valve
    NAT GAS
    3.5 wc high setting , 0.9" low
    4 terminal panel & molex connector
    contact the mfg. it was used for>>>>>>>>>>>>>>>
    So no help !! Can anyone recognize this valve??
    "My hands are for sale"
    i found this.
    Mar 2001
    Hunnywell makes a 2-stage/120v, dunno about 24v.
    New Jersey
    Go to honeywell.com
    I think you need a vr8305q4146 two stage valve
    Nov 2002
    Thumbs up
    Thanks Guys!!!
    Found a replacement from Honeywell. I'll find out Monday if our supply house's have it in stock.
