Page 3 of 3 FirstFirst 123
Results 27 to 32 of 32
  1. #27
    Charlottesville, VA
    Also, would there be a problem mixing a High Velocity system with a conventional AC ducted system? I know it is not necesarily the most elegant solution, and I will continue to look for alternatives, but was wondering if it would cause a problem?
    B
    Quote Originally Posted by bartmanbartman9 View Post
    So we had one of the local residential contractors come out and look at our system and provide options.
    Basically, based on his load calculation, our current system is under powered by about 0.5 tons (we have a 2 ton system and he calculated a need for a 2.5ton). He's calculating a total of 4.5 tons needed for the existing structure and the addition. His suggestion, put in a conventional heat pump into the addition (2.5ton) and try to duct some into the existing structure. Sounds like the cost is going to be prohibitive to upgrade the chiller and the Spacepak.
    Thoughts?
    B
  2. #28
    Jan 2001
    Pamnyra VA.
    what block are you on in c vile ?
  3. #29
    Charlottesville, VA
    Quote Originally Posted by skibme View Post
    I'm in western Albemarle.
  4. #30
    Jan 2001
    Pamnyra VA.
    i work for the university. let me take a look, maybe i could recomend someone to help you out.
  5. #31
    Having a conventional for one area, and a HV for the other , doesn't cause any problems.
  6. #32
    Charlottesville, VA
    Thanks. You can email me at brn3a at the University too.
