    flow valve fake out
    the return pipe on the peerless water boiler system I have goes from hot to warm to cool sometimes for a little while, which in turn causes the forced hot air to be warm to less warm to coolish. The circulator lights are on and the circulator seems like it's running. However, when I tap lightly on the Taco 218 Flow valve with a small hammer all around...I can get the water to flow after a while and return to hot. This lasts a while then the process starts again. I don't ever remember this happening before. I tried backing out the thumb screw for constant 'open'...it helped a little but still things don't seem quite right. Could it be something else like the thermostat, or some other issue. The blower seems to be running more than normal.
    Bob
    Apr 2003
    the Great Pacific Northwest
    Could be a circ. pump, but working on boiler systems should be left to pros.
    Several possibilities.
    Call your service company. They can trouble shoot it, and fix it.
    flow valve fake out - revisited
    it seems that backing out the thumb screw temporarily fixed the problem. We're getting warm air now. I realize this could be due to gravity and the density difference between hotter and cooler water. So, it may still be the circulator ?? But not sure ....
    Bob
    Quote Originally Posted by physics View Post
    Bob
    Philadelphia, PA
    This is the best advice you could get. In the long run your comfort will be improved and the system will run less resulting in lower utility costs.
