Page 3 of 3 FirstFirst 123
Results 27 to 38 of 38
  1. #27
    MN
    Quote Originally Posted by ChrL_Brann View Post
    Around here you are suppose to run double wall pipe all the way.
    gottcha, makes sense then. here if there is enough clearance to combustibles regular pipe is ok.
    You can't fix stupid
  2. #28
    Jun 2007
    Greenville,North Carolina
    Quote Originally Posted by cmajerus View Post
    That is the way it use to be around here,just changed it recently.
  3. #29
    Wicked awesome install!
  4. #30
    INDIANA
    what is that black tape for? do they think it was going to stop a water leak.
  5. #31
    Sep 2006
    The depths of hell in PHX AZ
    wow
    I will believe that the government is broke when the welfare checks start bouncing!!
  6. #32
    its redneck engineering at its finest
    http://www.youtube.com/watch?v=nFl0n...ture=endscreen
  7. #33
    Madison, Wisconsin
    http://www.waterheaterrescue.com/pag...ielectric.html
    link to a place where they have flex lines for connecting the HWH. I guess this is what they were trying to do. My dad said that they do all of them like this in TX. It is code.
    I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
  8. #34
    Must be a local code. IFGC vent tables will allow single wall galv. In fact, furnaces can also be single wall vented when the data meets the vent table requirements until it connects to b-vent prior to going through the ceiling.
  9. #35
    Jun 2007
    Darby, PA
    What is the PSI rating for the gas flex? Why didn't they burst?
  10. #36
    Jun 2007
    Quote Originally Posted by ldmth44 View Post
    The only thing I can say,its like the tootsie roll pops.....the world may never know!LOL!
  11. #37
    S.E. Pa
    Cool
    Dormont, who invented the stainless flexible gas appliance connector rates their connectors at 5 psi but actually tests them to 125 psi. Gas only. They make special connectors for specialty gases. You can use those copper flex lines in seismic zones but not gas flex.
    Regardling the galvanized vent connectors, can you say where this is code? It is allowed by both the IFGC and NFPA 54 except in concealed and unconditions spaces such as attics, crawl spaces and walls. Single walled pipe carries a 6inch clearance to combustibles. The sizing tables in the gas codes assume a 12" rise right off the draft hood before any offsets. You should never put an ell right on the draft hood or it may find it easier to spill into the CAZ rather than up the stack. Make sure you screw those pipes together--I rarely see screws or supports.
    If your AHJ requires something that is over and above the gas codes, ask him where you can get a copy of the local ordinance. If there isn't one and he's just playing God, he cannot legally fail an inspection or hold up a permit.
    I'm guessing a DIY'er who cannot sweat copper used those flex lines.
    Heathman.
  12. #38
    Thats impressive. I cant believe it holds the pressure! Good pics!
