Results 14 to 26 of 38
    Austin, TX
    Dam, I had no idea they would hold that much pressure.
    Oct 2006
    In a freezer or in an attic somewhere
    Is that duct tape on the flex line? Maybe it wouldn't hold gas, but with the tape on there it will hold H2O.
    UNREAL????
    Jun 2007
    Greenville,North Carolina
    Quote Originally Posted by reepersteve View Post
    UNREAL????
    Its electrical tape,I have never seen this before in my life...Till this one.
    Jan 2002
    Ft.Worth,Tx
    Thumbs down Diy
    No plumber would do that, it's a DIY special. Twisted homeowner with too much Home Depot experience.
    "Everyday above ground, is a good day".
    "But everyday that you have made a difference in someones life, may insure you stay above ground a little longer".<aircooled>
    South Amboy, NJ
    yeah,thats gotta be someone with no clue what they were for....no one with a clue would ever do that...i hope!!!!
    Oct 2006
    Hey Mook, like the name. Now you need a avitar to match.
    Cool name, Mook
    MN
    Quote Originally Posted by lolson View Post
    not only the water piping is screwed up but the flu vent is galvanized pipe
    ok maybe i missed something, but whats wrong with the galv. venting?
    You can't fix stupid
    South Amboy, NJ
    Cool name, Mook
    Better?
    Oct 2006
    Cool
    Quote Originally Posted by mook531 View Post
    Better?
    It's all good, Mook.
    Massachusetts
    Quote Originally Posted by cmajerus View Post
    I wondered about that comment too. Galvy is legal in our state except you can't use 3-in with less than 12-in vertical rise to the first 90. But we find them all the time with a 3-inch 90 stuck directly on the draft hood.
    MN
    Quote Originally Posted by skippedover View Post
    how about no draft hood HO had his farm hand redo venting can't believe it drew enough air from the burner opening no rollout, no sooting. (nobody died) It has a draft hood now.
    homeowner special?
    Jun 2007
    Quote Originally Posted by AMS481 View Post
    homeowner special?
    I think it was which is very scary.Around here you are suppose to run double wall pipe all the way.
