Thread: Johnson NAE
    Johnson NAE
    Is there a way to map all points from a controller to the NAE all at once instead of mapping them one by one? I'm using an NAE model MS-NAE5521-0 with VMA controllers
    Add the long form printer file as a resource file to the device.
    When you add points use the resource file and select the points you want to map.
    Mar 2006
    Using the .prn is the way to go.And Do Not map all the VMAs points back in. That is a sure way to slow a NAE to a halt if you have alot of of them.
    At the risk of throwing a "me too" post out there...
    Do NOT map in all VMA points. The recommendation from JCI is to not map more than 23 points from a VMA.
    There's been "issues" with ridiculous N2 trunk traffic from VMA's--this seems to be mostly fixed in a patch 2.2.23 (or any version 3.0+), but the 23 point limit is still suggested.
