Results 1 to 13 of 17
02-27-2008, 06:21 PM #1
- Nov 2007
- 30
VisionPro setting Fan On and Circ?
When I set the stat to run on Circ. for one time period and Auto for another time period and you hit done should Auto and Circ. be displayed in the fan menu on the main screen?
02-27-2008, 06:23 PM #2
- Sep 2005
- Texas
- 2,793
I think not
02-27-2008, 06:37 PM #3
- Nov 2007
- 30
What am I doing wrong? if you don't mind..
Rock142
02-27-2008, 06:44 PM #4
- Sep 2002
- I don't know
- 2,888
Why would you want both to be displayed at the same time? It's about as logical as displaying Wake/LEAVE/Return/Sleep at the same time because they're included in the program.
I could be wrong - perhaps your t-stat just operates like that.
02-27-2008, 06:49 PM #5
- Sep 2005
- Texas
- 2,793
auto is for programming , ON is continuous, CIRC is a random feature
02-27-2008, 08:06 PM #6
It only displays the mode it's currently in. When it reaches the program setpoint for circ, it should display it then. It won't display both at the same time. Nothing's wrong.
02-27-2008, 08:21 PM #7
I haven't really paid much attention to the resi VP but the commercial VP does not display the fan mode. It always displays Auto even though the fan is programmed to be on.
02-27-2008, 08:55 PM #8
- Nov 2007
- 30
Thanks guys for your help..I finally got it right..
Rock142
02-27-2008, 10:13 PM #9
02-27-2008, 10:29 PM #10
If you go into the program menu of setting your time and temp, you can tell it to run the fan in that mode,
Example, Wake-On, Away-Circ, Home-On, Sleep-Auto. When in the normal menu, you set it to Auto, and when Wake schedule is on, Auto and On will show on the screen, then when it goes to Away, Auto and Circ will show up.
YOu can override it, say You want the fan to run ON all times, and not follow schedule, then on the normal menu you press till On is displayed, and the fan will stay in that mode.
02-27-2008, 10:30 PM #11
02-27-2008, 10:42 PM #12
02-27-2008, 11:25 PM #13
- Feb 2008
- 11
I have a visionPro also. whats is best to set to? Should my fan be on all day or CIRC?
