Results 1 to 8 of 8
    Victoria BC, Canada
    Chlorine resistant humidity transducer.
    Hi all,
    I have had some problem finding a humidity tranducer that will stand up to the environment in a return air duct from a swimming pool. The standard "off the shelf" sensors only last a few months. I tried a Johnson HT-6703-0N00P that did last close to 2 years but it has now failed. Has anyone tried any others that seem to tolerate chlorine?
    On the bay fishing
    I have had good luck with these from KELE.
    Beware of the prophet trying to make a profit.
    There is less oxygen from knee level to the floor! Check it out next time you tie your boots.
    Maybe your real issue is in the akalinity of the pool.............if your ph level is to low in the pool it can cause errosion and corrosion of metal. A chelating agent is what is used to metals such as copper in a pool for a HX ...........but im unsure if a RH% sensor have that good luck
    Jan 2003
    Pools will eat humidity sensors up eventually. I like the Veris and Kele units with replaceable tips. The tips are very cheap, and a simple install. Give the customer a handful and he will be set for a long time.
    Michigan
    Quote Originally Posted by eriks1954 View Post
    Hi all,
    3 years on JCI parts, send it back for a replacment
    "Yeah I can figure out whats wrong with it, but you were here first and there isn't room for two, plus it's cold up here, I'll be in the van"
    Nov 2007
    I would go to an industrial grade transmitter. Vaisala is one of the best transmitters http://www.vaisala.com. I know they make corrosion resistant ones.
    UK
    I would second Vaisala. Certainly worth the money.
    gnomethang
    _______________________________________________
    "Once men turned their thinking over to machines in the hope that this would set them free. But that only permitted other men with machines to enslave them."
    - The Reverend Mother Gaius Helen Mohiam
    Victoria BC, Canada
    Thanks to all that replied.
    I will do some research on these products and go from there.
