Results 1 to 13 of 14
    Tell me how to remote a water source heat pump -
    High acid water is eating up the lines and fittings. The attic unit has flooded the house twice so far. It was replaced but the HO is concerned for water up there. Of course he doesn't want to just scrap the new unit.
    At first I was thinking that I could pipe in an air cooled HP condensing unit.
    But it just struck me today that I could just remote the water coil to the basement and run the refrigerant lines down to it from the attic unit.
    Any problem with doing that?
    PHM
    Tennessee
    would it not be easier to just treat the water before it enters the system?
    No -
    When the first coil let go - in the basement unit luckily, I had the water tested. It came back very high acid. So I replace the water coil with a marine grade unit and suggested that they get a water treatment system added for acid.
    They did - just for the house water. The installer wanted $15,000. More for a system big enough to do the 8-9 GPM they need for the heat pumps.
    So yes; it would be easier. But no; it would not be less expensive. And no; they will not agree to pay for it.
    I want the water out of the attic. One of these floods is going to be blamed on me. <g>
    PHM
    Jun 2000
    WYO
    No problem here.
    never say never
    Jul 2000
    Northern Wisconsin
    This is a problem that needs to be addressed with the manufacturer of the equipment. Making modifications to equipment that are not authorized by the manufacturer makes you liable and not the manufacturer.
    Jul 2002
    Slacking off right now
    Bad idea all around no good will come of this
    www.vetopropac.com - The best tool bags on the market - The offical tool bag of choice by techs everywhere
    Arguing with some people is like wrestling a pig - eventually you realise the pig actually enjoys it
    Gonads serve a useful purpose but are no substitute for brains
    SW FL
    Thumbs up
    Plate & Shell HX
    http://www.tranterphe.com/
    No one said it was going to be cheap!
    Designer Dan
    Feb 2007
    I hope you have enough liability insurance. Happened to me in a completely different situation, but the HO filed a claim with his insurance, they came after me, and I turned it into my insurance.
    Shouldn't be a problem.
    Hell Hole Swamp
    Go closed loop
    Putting a water source HP in an attic is insanity, I know because my previous employer did many and Ive seen the disasters
    Penguin -
    Why do you say that relocating the water portion of this heat pump from the attic to the basement will be a bad idea?
    Bad in what way?
    PHM
    Grottoes VA
    You are changing the design of the unit. The compressor was not designed to pump the refer 20 or 30 feet.
    I would just replace it with a geo split system. It will be cheaper in the long run. A closed loop would be a better option though.
    SW FL
    Question Root causes of the disasters /
    Quote Originally Posted by Swampfox View Post
    I've seen the disasters
    Problems were mainly due to _ _ _ ?
    1. Limited Access
    2. Attic Heat
    3. Water chemistry
    4. Poor installation
    5.
    6.
    Designer Dan
