Results 1 to 13 of 22
    Apr 2008
    Greenwood Lake, ny
    Cracked heat exchanger
    What other way is there to check for bad exchanger
    besides a visual inspection.
    Feb 2007
    Quote Originally Posted by ktw129 View Post
    What make and model heater? What kind of fuel?
    lugoff southcarolina
    Smile
    visual check on heat exchanger is the proper way to check
    Toledo, Ohio, United States
    Twilli closes his eyes and feels for cracks
    No Heat No Cool You need Action Fast
    Where I work we do a penatration test. This requires you to remove the blower. Inspect the heat exchanger before, look for protenial spots. Then squirt water on the Heat Exchanger form the bottom. Get it wet as possible. Then inspect again, if wets form on inside of heat exchanger you got cracks. Another test is the smoke test. They make a smoe bomb that you light off in your heat exchanger then turn on the blower and if you get any smoke out of vents you got cracks in your heat exchanger.
    leland nc
    Quote Originally Posted by twilli3967 View Post
    I find it more fun this way to
    Twilli still wants to know what kind of test can you do, without visually seeing the test result, and what test is better than seeing the crack, other than of course touching and feeling the crack
    Houston,Tx.
    Mr. Bill gets all the help he needs, I just stop by the local Stop and Buy and tell the Brothers I am about to go look for a crack in an HX and they all jump in the back of my truck.
    twilli cabonmonoxide test
    leland nc
    if you can see the crack then what more is need to find it
    the crack is there if you can see it
    Illinois
    Anyone care...
    to give the op some real answers
    somewhere between heaven and hell
    I use a scope but the scope still cannot get in some places so in that case I either pull the blower whether it is downflow or upflow and look inside with a flash light or if upflow and if I can take the spacer from the a coil I look down that way also then do what twilli does.
    If you have combustion analyser and do a orsat test you can sometimes detect a crack that way also
