Results 1 to 13 of 22
    Mix old coils with new unit?
    I have a 12 year old split system 5-ton Lennox AC, gas furnace in a 2000 Sq foot home that heats fine but needs a new cooler.
    I was going to replace everything until a friend of a friend who does AC work suggested I install a new Goodman 13 SEER R22 unit outside and keep the Lennox coils from my existing 10 SEER unit. He said he checked with Lennox and that the coils will work with the new unit.
    I'm new to all this but read you need to match the coils to the new system to achieve the stated SEER rating. Is this correct?
    Any thoughts would be greatly appreciated?
    Feb 2007
    I seriously doubt if anyone at Lennox who actually knew anything technical would tell your friend that it would be fine. Replace them both after your friend does a Manual J heat loss/gain on the house, and if you don't have a 90+ furnace, replace that too. Your "friend" is doing you no favors.
    Mar 2002
    Concord, CA
    Quote Originally Posted by cap2240 View Post
    Uh huh... No Lennox dude in his right mind said that.
    Work? Sure. Work correctly? Not a chance. If the old evaporator coil has a TXV then it'll "work". Efficiency will be less than 13 SEER and capacity will be less than 5 tons. But it'll blow cold. You might even be happy with it's performance. And it might even cost a smidge less to run than the old setup. That's not an endorsement of the idea, just a reality. It's really best to get a new coil.
    Massachusetts
    No doubt your advisor keeps the old radiator for his pick-up when he trades it and puts it in the new pick-up, right? Or is it the engine or the rear end? Just which part DOES he keep when he trades? Why treat your HP any differently? Don't be a cheapskate just 'cuz you friend is. He doesn't live in your house and he's not paying the bill. He's just trying to inflate his own ego by throwing around some technology. Every authority in the country will advise you to replace both units so you get a new mechanical system. I'd also go so far as to say you should have a current load analysis done (Manual 'J'), duct analysis (Manual 'D') and get an ARI certificate that the new system components meet the 13-SEER standard once it's all installed. Do it right and you won't regret it. As for the manufacturer, that's open to opinion. I'd search first for the company that will do the load analysis and then get their opinion on which system you should get. But no matter what, I'd replace the whole shootin' match. Shucks, I just pulled out a perfectly operating system in my own house and replace it with a new system, 2-stage, variable speed blower. Eletric bills are already down 30%!! Eat your hear out!!!
    Frisco , Texas
    You can replace the piston with a txv and the system will work although not as efficiently as designed, with the R22 the refrigerant lines need to be sized properly especiallly if run further than 50'
    somewhere between heaven and hell
    Cap do yourself a favor and avoid the headaches from later problems. Replace the coil ,line set, and the outdoor unit all the same time. It is best to match the coil with the unit to avoid further complications. You will be glad you did.
    A moonlighter
    selling Goodman
    says mismatch the coil
    RUN!!!!
    You're asking for trouble with a moonlighter and from someone willing to mismatch the thing. Nothing wrong with Goodman other than how common it is to be in the wrong hands.
    Yep. Someone just interested in making a quick buck.
    Stay with your original plan and match the coil and condenser. And use a real contractor.
    Nov 2000
    Eastern PA
    Quote Originally Posted by R2Kool View Post
    Absolutely not recommended by anyone.
    If you install a new condensing unit to an existing 12 year old indoor coil, you have a 12 year old system with a big new part that no one can say what capacity or efficiency is.
    Keep this friend for things other then HVAC and get yourself a new HVAC friend who is a qualified contractor.
    As has been stated; no one at Lennox has condoned this.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Ohio
    If this guy is lying to his friends like this....can you imagine what he is telling his customers??? WOW!!!
    I need a new signature.....
    Nov 2000
    Eastern PA
    Quote Originally Posted by I_bend_metal View Post
    The real tragedy is he probably isn't lying. Way too many technicians are convinced that using an existing coil is ok to do.
    Hope he lives near me so I can fix his goof ups
    Ohio
    Quote Originally Posted by mrlighturfire View Post
    Yeah...these guys are great for business!
