Results 1 to 13 of 13
Thread: HVAC Monitoring System??
02-25-2008, 11:16 PM #1
Looking for a hvac Monitoring system for a customer that is a snowbird?
Aint Notin Sweeter, Then A Brand New Heater!!!!!!!!!!
02-25-2008, 11:19 PM #2
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
Carrier Infinity,but you'd need a new system,somebody here likely knows of an aftermarket system.
02-25-2008, 11:23 PM #3
- Feb 2008
- 1,275
Tempurature monitoring is offered through alarm companies.
02-25-2008, 11:40 PM #4
Yes I have used the Carrier Infinity system, But a older couple a customer for years bought a new townhome and it is a new Armstrong system and i was trying to help them find something like the old pc8900 but that never worked that well.
02-26-2008, 01:14 AM #5
- Jul 2006
- MN
- 173
Check with wright/hennepin electric (whe.org)
I have several customers who are monitored by them. they can do temperature, water, fire, burglar whatever. and they serve a wide area around the TCs and nationally for others.
For a relatively small monthly fee and they supply the monitor equipment and place a callout for service. They can direct you otherwise if needed.
I also have seen a few internet capable standalone stats through Minvalco but never used them.
I monitor in our office a few places as well but they are a wee bit more involved than a home.
02-26-2008, 01:28 AM #6
Professional Member*
- Nov 2004
- SW FL
- 5,252
T / RH datalogger
http://www.coleparmer.com/catalog/pr...sp?sku=3571010
http://www.coleparmer.com/catalog/Ma...5710series.pdf
or Ask your neighbor to check !Last edited by dan sw fl; 02-26-2008 at 01:36 AM.
Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
02-26-2008, 08:11 AM #7
Thanks alot I willl call them today.
02-26-2008, 10:13 AM #8
- Jan 2007
- Minneapolis, MN
- 396
I have not used this and there are probably others like it but check http://www.icontrol.com/ for some info.
02-26-2008, 10:32 AM #9
- Feb 2007
- 18951
- 1,593
I don't think anyone can consider this a "monitoring system", but I have sold several of the Honeywell S483B1002 Winter Watchman (Honeywell retail consumer # CW200A1032) to customers. It's a line voltage thermostat that plugs into a receptacle. You turn a lamp on and plug it into the Watchman. Then put the lamp in a window where neighbors can see it. It can be set from 30 - 60 deg. F. I carry one on the truck, and have even loaned one to good customers who are going on vacation in the winter.
http://customer.honeywell.ca/honeywe...aspx/S483B1002
02-26-2008, 10:51 AM #10
- Feb 2008
- NY
- 98
Looking for pro help, not sure where to post
Looking for some pro help...
I own a Armstrong Air Ultra 80 oil furnace LUF80C112/125D20-1
I want to replace my very old 8 SEER 3.5 ton outdoor compressor.
My game plan...
Replace the compressor with a 3 ton unit (I find that the current unit simply is not on that much in the summer (we do not put the temp. lower than 76 in hot weather) and we are usually very comfortable.
I plan to buy a 3 ton Amana 18 SEER compressor (ASX18 0361A) and want to be sure I get the right coil to match.
Looks like uncased coils CAUF3642D6A, CAUF4860C6A or CAUF4860D6A should match. (actual width might be an issue)
The SEER ratings are based on a variable speed fan. My Armstrong Unit has a single speed direct drive fan with time delay.
The folks at Armstrong gave me the part numbers for their 18 SEER unit and said I would need an Expansion Valve (part A4TXV0TTXV) to go with the coil.
The Armstrong rep also said my fan is rated for 5 tons (seemed high to me)
Can this set up work?
What does the Expansion Value do and do I need it?
Is the ASX 18 0361A a good buy for about $2,500?
Please note - I am not trying to do this on my own, just trying to get the best info.
Thanks,
Jrongo
02-26-2008, 11:06 AM #11
- Aug 2006
- Dallas (Plano), TX
- 160
Using this product, http://www.welserver.com/index.htm :
This company, http://welserver.com/WEL0076 , is planning to set up HVAC energy Internet-based monitoring on up to about 1000 homes in the huricane ravaged area of New Orleans.
Here's a map of 10 installations where installed sites have agreed to be identified: http://welserver.com/ww . Of the 10, three are in Canada.
This is what I'm using for my WaterFurnace heat pumps - I'm at http://welserver.com/WEL0043 (Dallas area example).
I'm aware of one Dallas area HVAC firm contemplating offering a performance monitoring service using this system/product.
Best regards,
Bill
02-27-2008, 12:09 AM #12
- Jul 2000
- Northern Wisconsin
- 1,566
If you just want to monitor indoor temp and call if it falls below a low limit try http://www.sensaphone.com/sensaphone-400.html
02-27-2008, 12:21 AM #13
Thanks fire, thats exactly what I was looking for.
