Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 48
Thread: Heat pump reset
  1. #27
    Heat pump reset
    Thanks for all the suggestions.
    To gsxrsquid and wrench tech, the unit makes the hissing noise while it is in heating mode, and the tech that was out mentioned that it was a scroll type compressor. When it goes into defrost (which I witnessed a couple of times) the hissing stops. Then when it went back into heating, the hiss came back. The defrost lasted a couple of minutes at most.
  2. #28
    Grottoes VA
    Where are you located? I am almost positive I know what the problem is. The Rheems of that era had a problem with the defrost stat. It would only be a problem when temps were very cold outside.
  3. #29
    Jun 2007
    Piedmont Triad, NC
    You said the hissing stops when it goes into defrost. (cooling mode) There is the possibility that the reversing valve is sticking and not moving like it should. I have seen it happen and it does make it hiss. The tech can check the temperature difference across the reversing valve to see if it is leaking through. If there is no difference in temperature across the valve it's ok. If there is a differnce, the valve could be leaking through and therefore making a hiss when it does.
  4. #30
    Heat pump reset
    Quote Originally Posted by karsthuntr View Post
    I love your area. Spent a week with friends at a resort between Harrisonburg and Elkton last summer. But unless you will be in Southern New Jersey sometime soon..............
    Would this arise after 11 years without a problem?
  5. #31
    Feb 2007
    Quote Originally Posted by chuckweasel View Post
    Yes it could. Like anything else mechanical, it can eventually wear out.
  6. #32
    Grottoes VA
    You mean Massanutten (Mass of nothing)
    Bobb hit it on the head. I am still replacing the bad defrost stats. Of course I make the unit better and more efficient with the part I replace it with.
  7. #33
    Jun 2007
    Piedmont Triad, NC
    Wink
    Maybe I need to buy my parts where you do. Sounds like you have the inside track on parts
  8. #34
    Grottoes VA
    Quote Originally Posted by wrench tech View Post
    No, not really, I use a common Rheem part, it just not the OEM part. I just use my knowledge to increase the performance of the unit.
  9. #35
    Feb 2007
    None of the new Rheems I've seen come with that pressure switch. Soooooo, they either found a high tech stealth way around it, or said screw it, they are more trouble then they're worth. Makes you wonder if you actually need them if the charge is right and everything is clean.
    How are we gonna make any money if all these companies start getting everything right?
  10. #36
    Feb 2007
    Some of the Rheem boards can be repaced with ICMs.
  11. #37
    Amory Mississippi
    I have been using all ICM boards on the rheems. They have worked fine
  12. #38
    Grottoes VA
    Quote Originally Posted by gsxrsquid View Post
    The board is not the problem.
  13. #39
    Amory Mississippi
    someone close go fix this machine and tell us what was wrong. lololol
