Results 1 to 11 of 11
    Hmm evap. coil squeeling
    coil squeeling in heat mode outside unit 13 seer goodman heatpump inside coil is mortex coil for mobilehome ahu. cold outside when unit comes on makes loud whistler sound maybe for 10 to30 seconds. loud enough to wake you up.installed 1/2008 changed coil out 2/08 still have same problem. system was bought as match set coil TXV no orfice. install alot of the systems no problems like this if you can help it would be ablidge!
    Jun 2007
    south carolina
    did you change the line set when you changed the system?
    Feb 2007
    Are you sure it isn't a motor squeeling? Never heard of a coil squeeling.
    almost sounds like an obstruction did you get a pressure reading during this phenomenon?
    Quote Originally Posted by super_tech_1 View Post
    yes 7/8-3/8 recommend
    Quote Originally Posted by mike_miester View Post
    yes sound like a restriction psi look ok no sudden swing unit heat ok
    Jul 2005
    Is it a bi-flow TXV?
    Quote Originally Posted by bobb25 View Post
    no not a motor!
    Quote Originally Posted by hvacrmedic View Post
    it post tohave built in checkvalve no noise in cool mode .
    weber's Avatar
    weber is offline Professional Member/Membership Committee
    Southern Ca, Elkton Md
    Defrost?
    "Correct Installation is the Key"
    .1 has killed more HX then Rush Limbaugh
    What is your TESP?
    North Carolina
    I ran into an overcharged recip that did this once. Squeeled like a stuck pig. You might try a mechanic's stethascope to pinpoint the loudest point.
