    Jul 2002
    Duct in Exterior Walls
    Is it acceptable to run 6" oval supply duct in exterior walls or is there a problem with it - insulation or other wise?
    Thank You,
    Lancaster PA
    Unfortunately, its done.
    Worse place to put it.
    Feb 2007
    If it's for heating, you could lose a lot out the wall. If it's for cooling, and touches the wall, you could ruin it eventually. If it's the only place you can run it, I'd recommend spray foam between the duct and wall.
