Results 14 to 26 of 31
    weber's Avatar
    weber is offline Professional Member/Membership Committee
    Southern Ca, Elkton Md
    Quote Originally Posted by RoBoTeq View Post
    I understand what you are saying, but for a badly operatiing condensing furnace to operate at a lower efficiency then the best running 80% furnace, that condensing furnace would be shutting down on one safety or another.
    Besides, when we get into these scenarios we must assume that the equipment is operating as it was intended to do so.
    I see it more often then you would think!
    I have calculated 90% running at 67%, with no problems other then gas consumption. Thats what a combustion analyzer is for. And the customer loves you next month when they get thier bill!
    But yeah, for this scenarios we are assuming that everything is operating properly.
    "Correct Installation is the Key"
    .1 has killed more HX then Rush Limbaugh
    What is your TESP?
    midwest
    Quote Originally Posted by weber View Post
    What did that furnace have for an exhaust temperature?
    midwest
    Just wondering why no reply?
    weber's Avatar
    Quote Originally Posted by trane View Post
    Wow, I didn't know there was a specific time I had to answer your questions in. You do know its a monday morning, right? Lots to do!
    What is your TESP?
    weber's Avatar
    I dont have an exact # to give you, because everytime I see this problem it could be high or it could be low. It depends on what is causing the issue and what repair needs to be done to correct it.
    What is your TESP?
    Western Wa.
    Wouldn't that have a melted flue?
    weber's Avatar
    Quote Originally Posted by buttwheat View Post
    Why would a lower or slightly higher then normal temp melt a pvc flue?
    What is your TESP?
    Western Wa.
    If a 90% is running at 67% the exhaust temps. are going to be a little more then slightly elevated. it would turn the pvc in to a limp noodle.
    weber's Avatar
    Thats not true, and I can not give you any technical information to clearify, due to your membership and location of this thread.
    There are many things that go into effecting eff, not always over heating the flue.
    What is your TESP?
    midwest
    90% less 67% = 23% If its not going out the flue where is it going?
    weber's Avatar
    Its not always a burning issue but sometimes a mechanical issue were the 23% is not there. Basicly it has been derated. So your 100k furnace is only running a 70k. Your eff as far as what you are burning can still be higher, maybe even 90%, but your input has dropped so your output has dropped, So your are burning ok what you are burnning but you are not getting the proper output due to lack of input.
    So no, the 23% is not going out the flue, because it not there. And thats why you could have a lower flue temp.
    What is your TESP?
    midwest
    Then that 67% number was a mistake?
    weber's Avatar
    Customer wants 100K furnace, what is being supplied to conditioned space.
    If the customer is not getting 90K btu what are the getting? As far as fuel consumption, thats a different story, and it is on a case by case. Sometimes there will be a 70% out put from a 100k input on a 90%, with a higher flue temp. Im just stating different cases that could cause a lower flue temp.
    I dont keep a record of every sevice call I have every done, sitting next to me. So I cannot supply you with exact #'s.
    What is your TESP?
