    michigan
    Co2 kit for 5 ton trane w/ reliatel
    Does anyone have a wiring diagram for a c02 sensing kit for a Trane 5 ton with Reliatel controls. I would greatly appreciate it. Im installing it this week and trane sent the instructions for a 12.5 - 25 ton . They are similar but a little different.
    they use the same reliatel board. you should just plug the co2 sensor into the economizer control board - should be labeled right on the board. have you seen this board ?
    Quote Originally Posted by dmd-marc View Post
    did you get my email?
    good luck.
    The weak aren't destroyed by the strong.
    The weak are destroyed by the under-estimated.
    michigan
    Sorry jayguy I didn't get your email. I need the wiring digram for the co2 sensor w/ vent override kit for 5 ton reliatel. If you have it I would greatly appreciate it.
    lets try it this way....
    good luck.
