Results 14 to 26 of 30
Thread: Hot Room Question
02-24-2008, 12:06 PM #14
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
You can find a manual damper that can be controled from in the room,search the net.
02-24-2008, 12:06 PM #15
Banned
- Jan 2008
- 109
02-24-2008, 12:19 PM #16
Banned
- Aug 2002
- 18,836
02-24-2008, 12:43 PM #17
Professional Member*
- Jun 2007
- Round Rock
- 2,920
02-24-2008, 12:52 PM #18
Banned
- Jan 2008
- 109
The room cools perfectly in the summer. The only problem is that it gets too hot in the winter. Sure sounds like the slave solution is the best one, but would be more work/cost that the manual damper solution.
As for dampers that can be controlled in the room, are you referring to the dampers built into the grill? If so, my experience has been that when I partially close them, they become noisy (wind whistling through the grate). I am hoping you are referring to something different, but did not find anything doing a cursory search of the net. A link would be greatly appreciated.
02-24-2008, 01:05 PM #19
Banned
- Aug 2002
- 18,836
Damper has a cable ,like a lawnmower throttle,sorry I don't have a link.
02-25-2008, 11:38 AM #20
Banned
- Jan 2008
- 109
02-25-2008, 08:24 PM #21
- Nov 2004
- SW FL
- 5,356
Bowden Cable
Now you have a link ... Young Regulator
... available at your local air distribution wholesaler.
http://www.youngregulator.com/pdfs/b...to%20cover.pdf
http://www.youngregulator.com/pdfs/s...l5020-1200.pdf
http://www.youngregulator.com/products.aspDesigner Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
02-25-2008, 09:14 PM #22
- Jun 2007
- south carolina
- 175
02-25-2008, 09:27 PM #23
Yes and it works well in rooms that the btu's needed, change on an hourly, daily, weekly, or even seasonably.We use t-stats only for control to prevent human error(forget to turn on/off and equipment overheats.).Most of our zone/equipment room installs require equipment not to overheat, using the existing a/c. DO NOT ATTEMPT ON YOUR ON. Found a qualified contractor and one who has installed zone systems prior.Last edited by KirtusJon; 02-25-2008 at 09:28 PM. Reason: spelling
Too Few Pro Tech's & Too Many Parts Changer's.
02-26-2008, 08:58 AM #24
Banned
- Jan 2008
- 109
02-27-2008, 03:15 PM #25
- Mar 2002
- Concord, CA
- 2,628
Let us know how it works. When you reply, most contributors will get an e-mail even if it's months later.
I think the slave zone system proposed doesn't actually turn the system on. If not, and if you find later that you want that ability, I just came across this. It might be useful.
02-28-2008, 01:32 PM #26
Banned
- Jan 2008
- 109
Just got the quote from my HVAC pro on the motorized dampers (w/ themostat control) and it proved to be cost prohibitive
I asked him to work up a price on the cable controlled options. We'll see where that takes me.
