Results 40 to 45 of 45
03-05-2008, 09:50 AM #40
- Apr 2005
- 53
For your comparison:
Live in 1700 sq. ranch in Middle TN. All electric, non-insulated crawl space, non-insulated floors, 3 ton heat pump, 2 adults, 1 teenager. KWH last month was 1690.
03-05-2008, 11:27 AM #41
- Apr 2005
- 53
Also should mentioned we keep the thermostat set at 72 degrees, 24/7.
03-05-2008, 12:10 PM #42
- Oct 2003
- Valdosta Ga
- 847
Server s;ow Tenn is warmer is warmer I think , Floor ins sounds like a good way to go. Was the builder endorsed by your local Electric comany
03-05-2008, 05:47 PM #43
- Apr 2007
- 19
i also live in Southern Missouri and I am a licensed HVAC contractor. The first thing that always comes to mind when a customer calls with a high energy bill, especially with a heat pump is that something is probably wrong with the outdoor unit.
03-09-2008, 08:33 PM #44
- Feb 2008
- 12
Thanks for the responses guys. Fisher01, I would think perhaps it has been warmer where you are at, but i am not sure. I was also able to compare with another house that has an uninsulated crawl space, and is 200 sq feet smaller than mine. They also take more steps to save than I do (unplug everything, unscrew light bulbs in the kitchen, etc, an their bill was only $10 less than mine! I am starting to think this is the nature of a house with a crawl space, or perhaps an uninsulated crawl space?
03-09-2008, 09:13 PM #45
Uninsulated crawlspace is getting both of you.
Don't forget. The same HVAC contractor may have put that other system in also.
2 bad installs don't make him right.
