Page 1 of 5 12345 LastLast
Results 1 to 13 of 53
    ABQ,NM
    Is This Acceptable Workmanship???
    I don't know how hard it is to make the exhaust duct mate up with the machine without taking tin snips to the furnace door???
    Houston,Tx.
    Quote Originally Posted by 16F-MAD View Post
    That was wrong period they would be giving me a another furnace or at least door.
    Minnesota
    Would this happen to be a Payne unit, supplied by a Home Warranty Company?
    White Bear Township, Minnesota
    www.summitheating.com
    somewhere between heaven and hell
    That furnace has a knock out why did they chop it all up like that I would sure recommend a new door you paid good money and you should be pleased at end of job. Make them get you a new door. And make them only use the knock out for the side no need to make hole any bigger than the knock out.
    Houston,Tx.
    Quote Originally Posted by mrlighturfire View Post
    Exactly!
    Washington
    You guys are splitting hairs here. Carrier should've been hit in the head when they designed these doors to begin with.
    Did he miscalculate his vent height a little? sure. Does it really make a difference unless you are staring at it? no.
    I'd be more concerned about the fact I got myself a cheap 80% furnace.
    Houston,Tx.
    I would also be a little concerned about the sharp edge of the door after a period of
    time possibly cutting into the vent pipe.
    Quote Originally Posted by seatonheating View Post
    Exactly!
    Washington
    C'mon Bill, even you don't believe that one.
    Houston,Tx.
    What that this could not happen?
    Washington
    Highly, highly unlikely. The furnace will die many years before it would happen, if at all.
    or you could cut it enough that i won't even touch i too am unsatisfied with these doors, but what can you do besides the best you can? i haven't had to cut one myself
    I agree I am not a fan eitherof this design at all to me it looks cheap and the doors hardly match up when putting it back on they really don't give you much room with the b vent inside the furnace. I was installing a down flow 80% went out the side like that what a pain it was. But I never had to chop up the knock out like that admitting it is pain in the ***.
