Results 1 to 13 of 18
    Balancing Question
    In a 2400 Sq ft home w/ 8 rooms spread on two floors (7 on floor 1; 1 on floor 2) there is a central Central Air system (and heat pump). The entire home is a single zone w/ the thermostat in the largest room on floor 1. What is a reasonable expectation in regards to how much the temperature would vary from the room w/ the thermostat? I know that in a perfect world, the temperature would be identical in each room, but I also know that this probably not realistic. I also know that if it varies by 10 degrees from the room w/ the thermostat, there is a problem. But what I don't know is where the line of acceptability is. Is it at +/- 4 degrees from the room w/ the thermostat, +/- 3 degrees, +/- 2 degrees +/- 1 degree?
    Thanks in advance.
    wash dc metro area
    Hey Ivan
    My company's gaurantee is +/- 3 degrees with the fan left on the "on" position and +/-5 degrees in "auto". This is assuming the outdoor temp is within design limits and that the builder has the required ammount of insulation and draftstop. This is our standard for the thousands of tract homes we do each year. Custom homes we use lots of zone control systems and mini-splits to provide better comfort.
    I am at +/- 3 degrees. Sounds like I am OK. Just feels a little funny when I walk from one of the rooms that is +3 degrees from the thermosat to one of the ones that is -3 degrees. That 6 degree swing is very noticable.
    6 degree temp difference from room to room is extreme. Better sizing/ duct design is key. Tract house or not.
    Feb 2007
    A lot depends on how tight the house is. With a good envelope, 6 degrees is high.
    SW FL
    Thumbs down ... not even close to a hint of Quality !
    Quote Originally Posted by fincomber569 View Post
    T-stat set point = 75'F
    Do you actually mean that 70' F in one room and 80'F in another room could be considered a Guarantee?
    ... without something of QUALITY, Guarantee is definitely a misnomer.
    guar·an·tee /ˌgærənˈti/ Pronunciation Key - Show Spelled Pronunciation[gar-uhn-tee] Pronunciation Key - Show IPA Pronunciation noun, verb, -teed, -tee·ing.
    –noun 1. a promise or assurance, esp. one in writing, that something is of specified quality, content, benefit, etc., or that it will perform satisfactorily for a given length of time: a money-back guarantee.
    Designer Dan
    Dec 2006
    Just a homeowner, I heard the 3 degree difference from t-stat turning off from a tech and thought this was kind of high. I have since seen this number in numerous posts from the experts here so I consider it to be the industry standard.
    However, I have a similar situation to yours....3100 sqft home, 2 floors, one non-zoned system and have been able to achieve a difference of 1 degree at most from the thermostat at turn off. I did this by purchasing 5 thermometers from Home Depot, placing them in the same room with the thermostat to establish the difference in the thermometers from the thermostat. Then trial and error with the dampers to achieve the min/nil difference from the thermostat throughout the house. Took time (my wife thinks I am crazy) but I think it is worth it.
    Jun 2001
    Louisville, KY
    You'd be ripping that from my house. 10 degree swing???? Give me a break.
    Somebody needs to learn some duct design and rotate the design on the load calc to account for change in glass orientation.
    Houston,Tx.
    Quote Originally Posted by jrbenny View Post
    Well I have to give you credit JR at least you knew what he was talking about.
    Feb 2007
    Quote Originally Posted by 7474 View Post
    That's exceptionally good for a house of that size, but be careful not to restrict air flow too much, or the comfort you gain will not equal the damage you do.
    Dec 2006
    Quote Originally Posted by bobb25 View Post
    Thanks for the food for thought regarding airflow. I believe I am OK as most of the ducts remain fully open or with minimal dampering down, none are completely closed down. I guess it must be a properly designed duct system. Also, change my filter every month. Thanks again.
    Feb 2007
    Yes, it does sound like your ducts are designed correctly. A room almost never needs exactly the same btus and air flow that duct sizes come in. Do you have dampers on the take offs? If so, that's the best place to close them.
    Even though I admire you tenacity, I'm still not sure your wife is incorrect.
    Dec 2006
    Yes the dampers are at the take-offs. The more time I spend on this site, the more I learn and the happier I become with my HVAC professionals (new construction).
    Almost 4 years into marriage, I am pretty sure my wife is never incorrect
