Results 1 to 11 of 11
Thread: Drooping
    Nov 2001
    Seattle, WA
    Drooping
    Think there might be some stress on this outdoor coil? The corners on each end of dropped 1/2 inch.
    - Alexis de Toqueville, 1835
    Monmouth Junction-NJ-USA
    Gotta love the "Economy" option for the duct water proofing. LMAO. Must have been done by Hacker are Us!!!!!
    If you really know how it works, you have an execellent chance of fixin' er up!
    Tomorrow is promised to no one...
    Feb 2007
    So. Califorina
    Frown
    Looks like they at least put in flex connectors on the ducts (wonder if that was for noise transmission from the CFM rattling?). Oh for the lack of 2 8 ft.
    4" x 4"s
    Massachusetts
    I can't believe that just sitting there that thing would distort that much. Must have been dropped in by the crane operator. Maybe there was nobody on the roof watching and he just hit the release lever and let it drop from a couple of feet high. What a hack job! Heat 'Em & Cheat 'Em, Inc. no doubt.
    Nov 2001
    Seattle, WA
    Quote Originally Posted by skippedover View Post
    Three of these units were installed at the same time. This is the only one where the skids are mounted this way. Each year it droops more so I'm going back this week, I think, with my toe jack and put some 4x6 under each side. Hope the coil doesn't break.
    Florida
    powerup
    I'm with the opinion of Skippedover, crane operator dropped unit. I can not say that I have ever seen a unit start to droop, but hey, stranger things have happened.
    Oct 2006
    In a freezer or in an attic somewhere
    Cool
    Boys get your torches ready to light and your screw drivers ready to crape!
    That coil is going to pop.
    Nov 2001
    Seattle, WA
    Quote Originally Posted by reepersteve View Post
    Hope not. Took my toe jack to the roof, lifted up each side slowly, inserted some 6X4's, let it settle down and I hope over some period of time the cabinet will sit straight again. It's drooped this way over a period of about 5 years. The other end is perfectly straight.
    Arizona
    Is that a Lennox RTU?
    If it is, imagine if that was any other brand? Lennox metal is at least TWICE the gauge of almost any other Brand these days. Imagine if that was a POS Carrier installed like that?
    They wouldn't have been able to drive down the road before that biatch popped it's coil!
    True Heavy Metal Geek
    Nov 2001
    Seattle, WA
    There are 3 Lennox heat pumps on this roof all installed by a previous friend of mine as a referral. Mainly, I have had nothing but problems with all three systems. His install crew wired in the back-up heat thermostat lock outs in series with the electric heaters so that when the temperature -- on the roof -- got below 40 degrees the heaters came on, stayed on until the roof temp exceeded that 40 degree sitting. The heaters heated up the building to over 80 degrees at night which triggered the A/C on. So both were running at the same time.
    The owner of the building said each units power bill went up $300 per unit for the previous 3 months before he told me of the problems. He did call the install contractor back a number of times only to be told they were working correctly by thier technician. Then he complained to Washington Energy Services who handles the credit, I think, who also told the owner that there was nothing wrong with the sytems.
    I recommended heat pumps to him as a replacement of three 25 plus year old straight AC with electric heat as an energy saving measure. These Lennoxes also have economizers.
    I'd show you guys some pictures of the total install which cost this owner $25K with a $5K credit through some kind of energy rebate. A year after these installs I replaced two units on a separate building next door just because I was ashamed of what the building owner went through including the cost.
    I did it quick and easy with function in mind and not prettyness. The new three Lennox's installed by a large Lennox dealer...nothing but problems to date.
    My cheap and easy Goodman and Rheem install....not one problem, not one call, nothing...they just sit there and work. And my cost was much less and much quicker then my contractor friend.
    I'd show you the pictures but you guys would tear into me for months..and I wouldn't blame you. The thing is, sometimes the pretty things just don't work but the ugly things do. Lots of us guys on this board can relate to that statement. Can't always go by looks!
    Oct 2006
    Quote Originally Posted by DeltaT View Post
    Sorry Dude, for real, I,m, really sorry dude? When that thing pops, I will be playing the worlds smallest violin for you. Don't mean to be a a$$ O, but the other two are doing just fine. WTF POOOOOOOOOFFFFFFFFFF
    And when when it does, you'll be the,"round mouth of the day". watch!
