Results 1 to 13 of 13
    S.W. PA
    a/c on a submarine
    went to the Carnegie science center yesterday with the kids
    happened to see this out the window
    closer look
    could this be dices handy work? it is just down the road from his house
    MN
    that must be one of the new dual condenser's water/air cooled!
    You can't fix stupid
    Jan 2002
    Ft.Worth,Tx
    Lightbulb maybe a Dice special Not an Aircooled
    That's not one of aircooled's installs,no means of disconnect before .....
    DIVE!
    DIVE!
    DIVE!
    'Life begins with the journey each day'
    Oct 2007
    Midwest
    I hear those babies got a 40 SEER rating when they're underway
    Massachusetts
    Hey, that's probably some ol' swabbies handywork. Seems that our industry realy came into its own at the hands of ex-Navy mates who learned refrigeration in the service. All the civilians were still slidin' ice by the ton around and it was when the Navy guys came ashore that there were finally some people who knew refrigeration. So it's the Navy's fault we're all doin' this today!
    Jan 2003
    Kansas City
    That's a dive thruster. A 1075 rpm dive thruster.
    Norman Oklahoma
    Isn't that how they do the 750 hour salt corrosion test?
    Dec 2006
    McMinnville, Tennessee
    at least
    they did put on a liquid line dryar
    If you build it they will come,,,they built it and they went.
    Tampa, FL
    That sub used to be here in Tampa. I toured it as a kid. I don't recall if it had a/c then.
    I can't even identify the sucker. Haier maybe?
    a lot of offshore boats here have residential package units on them.
    DC Metro Area (MD)
    Almost looks like it says "YORK" down the corner panel here: http://i2.photobucket.com/albums/y30/dhvac/100_0457.jpg
    It's likely that submarine doesn't go underwater anymore I suppose. I can't say this is uncommon, though. I've seen similar masterpieces like this myself.
    St.Paul, MN
    Yep, good eye, looks like HDH series they were 12 seer.
    Remember, some poor fool has to work on what you install someday, and it might even be you.
