Results 1 to 13 of 23
    Chicago, IL
    Top Fuel Drag Racing Facts
    * One Top Fuel dragster 500 cubic-inch Hemi engine
    makes more horsepower (8,000 HP) than the first 4 rows of cars at the Daytona 500.
    * Under full throttle, a dragster engine consumes
    11.2 gallons of nitro methane per second; a fully loaded 747
    consumes jet fuel at the same rate with 25% less energy being produced.
    * A stock Dodge Hemi V8 engine cannot produce
    enough power to merely drive the dragster's supercharger.
    * With 3000 CFM of air being rammed in by the
    supercharger on overdrive, the fuel mixture is compressed into a
    near-solid form before ignition. Cylinders run on the verge of hydraulic
    lock at full throttle.
    * At the stoichiometric 1.7:1 air/fuel mixture for
    nitro methane the flame front temperature measures 7050 degrees F.
    * Nitro methane burns yellow. The spectacular
    white flame seen above the stacks at night is raw burning hydrogen,
    dissociated from atmospheric water vapor by the searing exhaust
    gases.
    * Dual magnetos supply 44 amps to each spark plug.
    This is the output of an arc welder in each cylinder.
    * Spark plug electrodes are totally consumed
    during a pass. After 1/2 way, the engine is dieseling from compression plus
    the glow of exhaust valves at 1400 degrees F. The engine can only be
    shut down by cutting the fuel flow.
    * If spark momentarily fails early in the run,
    unburned nitro builds up in the affected cylinders and then explodes with
    sufficient force to blow cylinder heads off the block in pieces or split
    the block in half.
    * Dragsters reach over 300 MPH before you have
    completed reading this sentence.
    * In order to exceed 300 MPH in 4.5 seconds,
    dragsters must accelerate an average of over 4 G's. In order to reach 200 MPH
    well before half-track, the launch acceleration approaches 8
    G's.
    * Top Fuel engines turn approximately 540
    revolutions from light to light!
    * Including the burnout, the engine must only
    survive 900 revolutions under load.
    * The redline is actually quite high at 9500 RPM.
    * THE BOTTOM LINE: Assuming all the equipment is
    paid off, the crew worked for free, & for once, NOTHING BLOWS UP, each
    run costs an estimated $1,000 per second.
    0 to 100 MPH in .8 seconds (the first 60 feet of the run)
    0 to 200 MPH in 2.2 seconds (the first 350 feet of the run)
    6 g-forces at the starting line (nothing accelerates faster on land)
    6 negative g-forces upon deployment of twin ‘chutes at 300 MPH
    An NHRA Top Fuel Dragster accelerates quicker than any other land vehicle on earth quicker than a jet fighter plane . . . quicker than the space shuttle.
    The current Top Fuel dragster elapsed time record is
    4.420 seconds for the quarter-mile (2004, Doug Kalitta). The
    top speed record is 337.58 MPH as measured over the last 66'
    of the run (2005, Tony Schumacher).
    Putting this all into perspective:
    You are driving the average $140,000 Lingenfelter
    twin-turbo powered Corvette Z06. Over a mile up the road, a Top Fuel
    dragster is staged & ready to launch down a quarter-mile strip as you
    pass. You have the advantage of a flying start. You run the 'Vette
    hard up through the gears and blast across the starting line & pass the
    dragster at an honest 200 MPH. The 'tree' goes green for both of
    you at that moment.
    The dragster launches & starts after you. You keep
    your foot down hard, but you hear an incredibly brutal whine that sears
    your eardrums & within 3 seconds the dragster catches & passes you.
    He beats you to the finish line, a quarter-mile away from where you just
    passed him. Think about it - from a standing start, the dragster had
    spotted you 200 MPH & not only caught, but nearly blasted you off the road
    when he passed you within a mere 1320 foot long race!
    That's acceleration !
    Jul 2001
    Iowa
    Thank You .....
    I have been looking for this list for quite some time. I can't remember where I read it....Drag News, National Dragster, or the like. The one I get the most resistance from is the revs per run...it's simple math, but most people miss it. The one I didn't remember, and am slightly confused over, was the stoichiometric efficiency factor. Stoichiometric efficiency of a naturally aspirated engine is 14:7:1 which I thought to be relative accross the board due to the definition of the term stoichiometric itself....(chemical reaction taken to compleation, or it's entirety.) Was that a typo, or do I need to re-read my fuel for dummys book? Any rate, I'm printing this out, laminating it and putting a copy in the trailer, and the truck...(for those after race drinkin bets) Thanks again
    Chicago, IL
    from wikipedia
    "For gasoline fuel, the stoichiometric air/fuel mixture is approximately 14.7 times the mass of air to fuel"
    for other fuels its different. so i guess nitro is only 1.7:1
    more cool facts:
    At top engine speed, the exhaust gases escaping from the open headers produce about 800-1000 pounds-force of downforce. If a cylinder fails during the run, the car may pull to that side due to unequal downforce
    The massive foil over and behind the rear wheels produces much more downforce, peaking at around 12,000 lbs when the car reaches a speed of about 325 mph
    New Mexico
    Chickaboom chickaboom don't ya just luv it!!!!
    Anything built to code is built to the minimum legal standard
    You can be anything you want......As long as you don't suck at it.
    SMW Lu49
    Liquid compression
    I enjoyed the facts, but:
    11 gallons of fuel per second?
    Say a 4-second pass~~ where is the 44 gallon fuel tank in a top fuelie?
    Say 50 gallons for the purposes of math:
    Say 4" bore X 4" stroke (12.56 X 4 X 8) (400 inch displacement)
    400 inches X 540 rpms = 216,000 cubic inches. (total displaced during a "run")
    44 gallons X 230" (cubic 'gallon' of mass) = 10120 cubic inches
    10120 / 216,000 = .047" of fuel per cylinder stroke?
    That doesn't seem like a lot.~~ I just don't see the 44 gallon volume of fuel being moved in 4 seconds.
    omaha
    Talking
    boss would not like you taking it on a service call
    Quote Originally Posted by DCN289 View Post
    Its variable......the motor will obviously be using more gas at 9500 rpms than at anything lower than that. Typically your motor isn't @ 9500 rpm's the entire run down the track.
    Your figuring for a N/A motor....remember this thing is force feed.
    You math is incorrect.
    http://www.epi-eng.com/ET-ThermEff.htm
    http://www.installuniversity.com/ins...n_9.012000.htm
    http://www.epi-eng.com/ET-VolEff.htm
    These are some nifty site for determining engine parameters...probably more than your interested in.
    Dec 2006
    NY
    14.7:1 is the best ratio for "complete combustion" ie the most enviornmentally friendly. The best ratio for power was a little richer than that, but leaves behind a little unburnt gasoline.
    Jan 2005
    Wisconsin
    If a car was doing 200mph, and the dragster took off at the finish line the same exact time the car got there, it would be a statistical dead heat at the 1/4 mile mark.
    It would take the 200mph car 4.5 seconds to cover the 1/4 mile, which would be about the exact length of time the dragster takes to cover the 1/4 mile.
    Therefore, the dragster will not catch the car in 3 seconds, but rather 4.5 seconds.
    The 44 amps thing to each spark plug isn't exactly welding much of anything.
    If we assume 12 volts, 44 amps about the same as a midsized car's alternator, you aren't going to weld much of anything.
    Typically ignition coils put's out very high voltage, but very little amps. That's why you can get hit with 60,000 volts, from an ignition coil and not get electrocuted.
    It's an interesting read, but seem's suspect.
    Quote Originally Posted by towdriver80 View Post
    For N/A gasoline. More like 11.5:1 for forced induction for safety or as high as 12.5:1 for high octane with water/meth injection for cooling the air stream.
    But this is for Nitro Methane so that's a different monster.
    Jan 2005
    Wisconsin
    I think the fuel consumption seems to be about 1.5 gallons per second, and not the 11.2 gallons per second, from what I have been reading.
    Quote Originally Posted by mikmic2 View Post
    Figure out the density of the air it breathes in to complete the run. multiply time 70% because of the optimal 1.7:1 ratio for nitro methane. Convert density from lbs to gallons for nitro methane. I lost my conversion chart
    Jan 2005
    Wisconsin
    Don't need no conversion chart. Here are a few fun facts from NHRA.com
    "that NHRA Top Fuel dragsters and Funny Cars use between 10 and 12 gallons of fuel for a complete pass, including the burnout, backup to the starting line, and quarter-mile run?"
    "that a fuel pump for an NHRA Top Fuel dragster and Funny Car delivers 65 gallons of fuel per minute, equivalent to eight bathroom showers running at the same time?"
    http://www.nhra.com/streetlegal/funfacts.html
    Doesn't look anything like the fuel consumption statistics used in this thread.
