Results 1 to 13 of 34
    Nov 2007
    Midwest
    Micron
    Moved Forum
    North Florida/South Georgia
    Mercury does not lie
    Call me old, go ahead, I can take it.
    If you could buy an electronic instrument that would give the same reading twice, I would consider it. It has been my experience with the electronic models that the reading fluctuates everytime.
    It will be fun to see where this goes, again.
    You could do a search & save yourself some time as this has been debated before.
    All my leon freaked out!
    Nov 2007
    Midwest
    Thanks Chiller Mek
    I did find a few good threads minutes after this posting.
    Tried to delete but we newbies get to fall down a few times
    Minutes after posting I did search the Tools Forum and did read through a few threads. But I'm wanting to know the best way to get an extended capicity CTV down to .5 mm Mercury without mercury. I've never been able to get my Vac-U Ator down that low. That's where the questions start popping in (not good ones either).
    All our Mercury Manometers have been confiscated, I am just having a hard time trusting the Vac-U-Ator. Maybe I should just get used to it! I just wish there was a foolproof/accurate test instrument that was inexpensive and robust.
    But thanks for your comments again!
    windy city
    Quote Originally Posted by Yipikia View Post
    Vac-U Ator!!! made by A&N products, ohio. Vac-Q , made by humbert, pa. where do you get the go-go juice for it. i'm striking out everywhere.used it forever, pretty reliable
    Cleveland,TN.
    [QUOTE=Yipikia;1764123]I did find a few good threads minutes after this posting.
    never give up my hg"manometer they are going to have to pry it out of my cold dead fingeres
    Nov 2007
    Midwest
    Carbonal
    Quote Originally Posted by heavymetaldad View Post
    Here is the contact info:
    A & N Products, Inc.
    5873 CHAPELHILL DRIVE, CINCINNATI, OHIO 45233 (513) 451-1721
    http://www.vacuator.com Fax (513) 922-3892 Cell (513) 703-8174
    The Vac-U-Ator™ kit is designed to retail for $110.00+. It comes in a kit with instructions, large
    P/T chart and empty bottle with pour spout. Carbinol liquid is purchased separately.
    Oct 2002
    Florida Panhandle
    First time I have heard of this product, please someone explain how it works.
    Roy
    A man is no less a slave because he is allowed to choose a new master once in a term of years.
    Lysander Spooner
    Oregon
    I used to have a Robinaire analog meter...I really liked it. It was pretty big and bulky. It seemed to work pretty well unless I got oil or junk in the transducer. I see they have the 14010A now....Haven't heard anything about them.
    I now have a Supco that came with my tools when I started at this job....I was pretty skeptical at first....hard plastic case and all....and my first evacuation and I only pulled down to 1300 microns...I thought it was I lying piece of cr**.....until I blew the chiller back up and found the leak I had missed I've had it for about four years now and still works fine. I've take pretty good care....don't drop it as much as I do my other tools.
    The Great country of Texas
    I still have and use my mercury manometer. I have the bar type Robinair and a Robinair vacuum tube type analog. The analog is good, bulky and you have to take care of the thermocouple. Alot of people are concerned about how deep a vacuum you are pulling, I agree but am more concerned about the amount of rise. I never agreed with Trane's 2mm or 2000 microns. If that's all I can get and that is their accepted rise, bet you it's got a leak in it. I can usually get one in the 500-700 micron range unless there is moisture in it.
    Bottom line, you have to take care of it and have it calibrated. I have been most happy with my u-tube. Unless it lost mercury, it does not lie!
    "I'm from Texas, what country are you from?"
    windy city
    Talking
    thank you, thank you! i had the darn box in front of me when i started on this mission 3 weeks ago. somehow the 'n' became 'r' - no can find. ordered a qt. w/ shipping for $79 . a million thanks again
    Charleston TN
    I wish they could make something electronic that could be reliable. Oh-reliable, that would be the good old mercury manometer. I know a lot of sites ban said device, but carrying it in inside your pocket does work most times as it should only take a couple of minutes to check the vacuum. It don't run on batteries which run down, hence trying like an insane scientist to get the same reading twice. Anyway, I think I just gave 3 cents instead of 2 cents worth there.
    We aren't service engineers, we are service re-engineers!! Work is what you make it, have fun.....
    Cleveland,TN.
    [QUOTE=stickerhead;1765233 I never agreed with Trane's 2mm or 2000 microns.
    hell sticker york's acceptable evacuation is 5k microns (IT'S IN THE BOOK)
    CHATTANOOGA, TN.
    Arrow
    NEVER LET ANYONE USE YOUR MICRON GAUGE, regardless which type you have. I do prefer a TIF 9450D,
    and have 3 of them.
    The GOV.
