+ Reply to Thread
Page 1 of 5 12345 LastLast
Results 1 to 20 of 81
Thread: HIGH SUCTION PRESSURE / LOW HEAD PRESSURE ISSUE
    Sep 2014
    Brooklyn
    Hey guys,
    need some help i am working on a carrier unit with a Scroll Compressor. I am getting 80 PSIG low side and 165 PSIG high side. Liquid Line is also very hot to the touch. I know this is not normal readings and since it's a scroll compressor, I am thinking about replacing the TXV. Thanx for the help.
    You are going to need to gather more info than that and post it because you are about to find out the TXV is not the problem.
    Jun 2014
    Dover, DE
    Time to put your gauges, meter and thermometer to work. Need more info.
    Jul 2009
    Damascus MD
    You mean.....hot gas line is hot to the touch?
    Need more info
    Aug 2009
    Maine
    That did sound like what he said didn't it.(:-
    Quote Originally Posted by gravity View Post
    Need more info
    Sep 2014
    Brooklyn
    sorry guys about not getting more info didnt have enough time cause i deal with all other stuff also, tommorow ill get the temperatures, but like i said the liquid line between the condenser and txv is hot to the touch, i know this line is suppose to be warm after the refrigerant subcools, the outlet of the TXV is cool but is not like super cold and theres no condensation. Im getting 80 PSIG suction pressure and 165 head pressure im kinda new to the field have about 2.5 years including 2 year tech school
    Sep 2014
    Brooklyn
    r22 system with scroll compressor 10.8 lbs of r22 compressor is running about 11 amps
    Jul 2002
    Sounds like valves; weird for a scroll. Is there any way to valve it off & try pumping it down? Stop the cond fan & see if she'll build some head.
    Arizona
    Quote Originally Posted by EdHvacr View Post
    Ed did they teach you about super heat and sub cooling at tech school?
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Oct 2011
    Chicagoland Area
    Give him a break guys, he has to deal with other stuff also, unlike the rest of you who just answer questions on the internet.
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
    Aug 2009
    Maine
    2sac that wasn't nice(:- Might be accurate, but still.......
    Quote Originally Posted by 2sac View Post
    Sep 2014
    Brooklyn
    lol, yes i know i havnt had time to get those readings SUBCOOL is condensor temp - liquid line temp, and SUPERHEAT = is evaporator outlet/suction line temp minus evaporator temp
    but just going by touching and feeling, ill say that subcooling is very low due to a hot liquid line, condenser is not rejecting enough heat ???
    Sep 2014
    Brooklyn
    i will try to use my thermometer tommorow for more info on whats going on everything that i read about concerning this symptom points finger at a txv im at lost first time i have encountered this problem
  14. #14
    Sep 2014
    Brooklyn
    i can try that, but can you tell me what this would be telling me because i am a little confused but i will try tommorow if i have time to work on it
  15. #15
    Sep 2014
    Brooklyn
    i wanna be able to fix this for brownie points and save money for not calling contractors, im the junior a/c guy here
  16. #16
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by lytning View Post
    If I started to act nice, you guys would think something is wrong.
  17. #17
    Oct 2011
    Chicagoland Area
    I'm curious as to what you've read that leads you to believe it's the txv?
  18. #18
    Jun 2014
    Dover, DE
    I know you want to fix it, but let's slow down and use some theory here. Diagnosis should never include the phrase "I think".
    You want to look good for the boss, but you also don't want to throw parts and money at the issue or make the issue worse.
  19. #19
    Jul 2009
    Damascus MD
    Could be low on gas and txv is wide open trying to maintain sh?
  20. #20
    Jun 2014
    Dover, DE
    SC should show the evidance of such. With a hot liquid line I think there might be several issues going on at once here.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
