Thread: Bakers pride y600 problem
02-16-2008, 03:19 PM #1
Professional Member*
- Jan 2007
- Frozen in UpState NY
- 56
Looked at a Bakers pride y600 deck oven for a fellow.
His complaint was "Fumes"
At start-up this thing puts off a very acidic smelling fume, burns he eyes nose and throat. it settels down after awhile.
I checked the flame color and found nothing but blue flames. I also noticed that the 2 burners were burning unevenly and attempted to adjust air/fuel mixture on the right side, but found it would not respond to additional air.
according to the owner the company that sold and installed it lost one of the orifices. They had a blank on the truck and drilled it. It was drilled way off center and the inside seem to be a bit chewed. I suggested ordering a new replacement.
Anyone have an Idea as to the cause of the fumes ?
02-17-2008, 01:01 AM #2
- Mar 2001
- 1,213
Aldehydes = poor combustion. Needs proper set-up.
02-21-2008, 01:10 PM #3
New Guest
- Feb 2008
- 2
You might want call the guys over at Parts Town. They're pretty helpful to me!
03-25-2008, 10:27 PM #4
Two ideas. First, the orifice must be sized correctly, centering is easy, they come with a dent in the center. Secondly, you will get fumes at startup for the incorrect combustion idea, or if they use or have used a cleaning agent in the deck. This usually is accompanied with light grey smoke at first.
"Fighting Ignorance since 1973 (Its taking longer than we thought)." The Straight Dope.
03-26-2008, 10:25 PM #5
- Mar 2008
- 9
check the burners to make sure they aren't partially clogged
