Results 1 to 13 of 33
Thread: Lineset cover
    Lineset cover
    We did this system for someone 2 years ago, nice neat lineset cover for the new refrigerant lines.
    Their neighbor liked the way it looked, so when he got his system replaced, he told his HVAC hack that he wanted a cover "just like it" for the new lines to his system.
    Well, it is the same exact cover we used...
    I'd have to look it up, but I'm reasonably sure this is in violation of the IMC...
    Harold would be so proud!
    the best part is if they moved the new unit to the right side of the old pad it would prob be straight
    NW AR
    Unbelievable. Did the H.O. install it himself?
    Howell, Michigan
    How can anyone in their right mind install anything like that.
    Jun 2006
    Southeastern Connecticut
    That was installed by someone who takes no pride in their work. But what is the code violation? I don't recall any codes addressing crooked piping.
    Jun 2006
    Quote Originally Posted by skoonen View Post
    After looking at the picture again, sliding the unit over to the right would have probably made it straight or a lot less obvious.
    Thumbs up
    Mark,
    Your Line Set Cover Looks Very Nice!
    true knowledge exists in knowing that you know nothing.
    Quote Originally Posted by dngtig View Post
    The crooked piping isn't the code violation, the penetration into the building is not "substantially rodent proof". I'm pretty sure that line is in the IMC somewhere, I'll have to look it up later.
    Arizona
    The disconnect (and being the OLD on at that) can't be behind the unit. THAT is against code.
    Not too mention DRINKING ON THE JOB!
    Because there is no way a sober person installed that cover like that and though it LOOKED good!
    Mark, you got to LOVE the night and day difference in the installs!
    Your install: TRANE
    Their install: GOODMAN
    Your Install: Nice and neat, all new electrical, whip, disconnect, etc and the straight line set cover.
    Their Install: GOODMAN (got to list that one TWICE), old disconnect, etc... and that line set cover... which is slanted for some odd reason.
    True Heavy Metal Geek
    What Is The R Value Of Metal Tape?
    Cliffside Park NJ
    How can anyone finish the install take a step back look at that mess and not fix it?
    Massachusetts
    They should have left the foil on their lunch.
