Page 1 of 4 1234 LastLast
Results 1 to 13 of 42
    What is static pressure?
    Guys about got my Infinity furnace system installed and watched the thermostat do a static pressure check.
    Have seen this on several other threads.
    Well what is it? Whats a good number to have?
    Phoenix Arizona
    static pressure is exerted on a duct in all directions and is something that velocity pressure(air moving down the duct) has to overcome...The higher the number the lower the airflow...
    "If history repeats itself I am so getting a dinosaur"
    Apr 2002
    Quote Originally Posted by Hrdworkingacguy View Post
    velocity pressure does not have to over come static pressure
    Fair enough, thanks
    Cool definition
    Its what I felt when i came home with no roses or chocolates-can lead to cold feet.
    phoenix, AZ
    take a five gallon water bottle with a 1/2" hose on the outlet. full of water, and turn it upside down. the amount of water coming out is like cfm. and the pressure in the bottle itself would relate to static pressure
    Oregon
    Static pressure is the pressure on the discharge side of your ductwork or fan system. Typically you would measure this with a magnahelic that reads in inches of water column. The high side port would be inserted through the side of the duct.....same as reading the pressure of air inside of a balloon.
    Total static pressure would be the pressure across a fan system or AC unit.
    High side probe would be inserted on the discharge side of the system and the low side inserted on the return or negative side of the system.
    Example 2 inches discharge pressure + .5 inches negative pressure = 2.5 inces total static pressure
    SW FL
    Question Long Enough ?
    Quote Originally Posted by Pegsmi98 View Post
    Fair enough, thanks
    http://www.udarrell.com/external_sta..._readings.html
    Designer Dan
    Airflow is likely different between heating and cooling cfms,so both need to be checked.
    SW FL
    Thumbs down
    simply ain't gonna happen
    Designer Dan
    Jun 2001
    Louisville, KY
    A good number to have...
    0.5 IWC or less.
    SA
    Quote Originally Posted by chillerfreak View Post
    never seen 2 inches on "discharge" supply side
    the data plate will let you know what to shoot for. checking static pressure should be done every time before checking charge in my opinion.
    Jan 2002
    Ft.Worth,Tx
    Infinity system would let you know if the static pressure was to high, because it would shut -down . Most run between .50 and .75 @ the measure cfm of ductwork. Static can be checked with Magnahelic.
    'Life begins with the journey each day'
