Results 1 to 11 of 11
    Jun 2007
    Keeping a Mr. Slim Fan "On" after an "Off"
    We have a customer that wants to modify the way their Mr. Slim Series MSH09 operates. From what I can determine, the unit fans are to operate continuously (in either heat or cool mode). The problem is that these units are in an assisted living center and the occupants can't stand the thought of something running when it shouldn’t be, therefore they turn the units “off” via the remote once they are comfortable. This is causing some mold issues. I understand the best thing is for the occupants to keep the fans “on”, but trying to convince 200 octogenarians that is another thing.
    We would like to run the fans for 8-10 minutes after the unit has been turned “off” via the remote. My thought is a delay on break time delay relay, but these are not standard fans. I have downloaded the service manual and looked at the wiring diagram, just not enough information. Has anyone ever tried to rewire a Mr. Slim? Outside chance I know, but thought I would throw it out …
    Thanks, Chuck
    Apr 2002
    the fan runs all the time as the temperature sensor is in the fan coil unit
    tell them the low wattage drawn by the fan coil constantly filters the air and reduces temperature stratification
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by Chukkuls View Post
    Where is the mold problem? In the MR Slim or the building? Regards TB
    Jun 2007
    Mold is on the exterior of the Mr. Slim indoor unit.
    Here and there
    Sounds like a give and take deal. Place is probably short on o/a and ventilation This compounds the problem.Take the remote away from the residents. a little mental discomfort beats mold
    Dec 2006
    Long Island, NY/ Columbia, SC
    ive heard nothing but horror stories from people trying to modify a mr slim a/h. best of luck if you try
    Here and there
    My sentiments, dont band aid where you need stiches
    San Francisco
    I gutted all the controls out of a mr slim once and installed a 24v controls system with the programmable stat on the wall. tired of the BS associated with the retarded remotes...all that
    it was easy. a couple relays, the transformer, and boom! online
    good deal
    you should be comfortable with basic a/c controls before attempting this! haha
    the thing that made it work is that I only needed one fan speed (full speed, max cool) and that the fan ran off line voltage. if you have a different type of fan that requires the solid state controls from the mr slim brain, you may not get away with it.
    manitowoc wisconsin
    mount the remote control in a lockbox.instruct maintenance on its proper use.
    Take your time & do it right!
    Hells Kitchen, Phoenix Arizona
    I think(but don't quote me) that mr. slim blower motors are DC inverter motors...I changed one a few years ago that was and it was a PITA...So I don't know if a time delay relay will work...I do know that their tech support is "OK" and has helped me with my issues from weird installs...
    I think the motor has a molex connector that has 3 wires im sure you could use a relay to break it somehow but without a schematic I can't tell you for sure...
    "Overkill is an often underrated achievement", Will Hayden -- Red Jacket Firearms
    New Mexico
    I guess if I saw mold I'd have to ? is the supply air too cold. If the units have some time on them a look at the fan might show the fan dirty. I know when they get this way the dirt will collect and moving less air will drop the temp.
    They are a pain to clean.
    Tracers work both ways.
