Results 1 to 13 of 16
    Ohio
    Arrow Braze vs. Solder...need some thoughts
    Well, I was sitting here thinking about something...what do you guys think is better for copper linesets? Brazing, the traditional way with torches and nitrogen....
    or
    Soldering with a turbo torch, flux and some #8 solder?? (no nitrogen needed)
    I need a new signature.....
    oh boy.....this may get ugly!!!Name:  69.gif
    Ohio
    Yeah it probably will, but I am not saying that one is right or wrong, just curious to hear what everyone's thoughts are
    Feb 2007
    Northern NJ
    soft solder is for water lines and drains. use brazing rods
    MN
    Quote Originally Posted by tjc76 View Post
    ditto
    You can't fix stupid
    wedged in freezer shelf
    leaks leaks leaks
    410 410 410 look out fire in the holeeeeeeee
    Dec 2006
    s.w FL
    why not braze with turbo torch?
    Ohio
    Quote Originally Posted by Downeasthvac View Post
    LOL...I guess I was talking more about a hand held propane torch with the trigger and all. Would take forever!!
    Myrtle Beach, SC
    Stay Brite # 8. Many use brazing rods without nitrogen, Stay Brite #8 would be better. Plus Stay Brite does not weaken the base metal like brazing does.
    But I can do it either way, and do.
    Remember, Air Conditioning begins with AIR.
    Ive used turbo torch in a pinch but you really need oxygen to get a hotter flame....and turbo does very poorly on large OD copper
    BAYOU LAND
    Quote Originally Posted by I_bend_metal View Post
    or
    I like to braze with 15% silver with a nitro purge
    and sometimes i'll even use flux
    has anyone tried that "COOL GELL" from Johnstone? pretty good to use on service valves,and to spray on insulation in attics when brazing!!!!IMO
    Ohio
    Quote Originally Posted by HVAC2B View Post
    Yes I have used that and it is good stuff....plus it washes away with water! Beats the hell out of Thermotrap! That stuff was nasty!
    If you are not brazing the lines with a silphos alloy, you are violating almost every manufacturers installation instructions.
