Results 1 to 13 of 13
Thread: Is it worth it?
02-10-2008, 09:37 PM #1
- Aug 2007
- Atlanta, Ga
- 213
Is it worth it?
Will it make any difference in air volume to increase the size of the supply grille and boot from a 5X8 to a 10X8....or 12X8.
Joe
02-10-2008, 09:40 PM #2
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
Very little without changing the duct size,unless it's the longest run in the house,then that much.
02-10-2008, 09:40 PM #3
02-10-2008, 09:59 PM #4
- Aug 2007
- Atlanta, Ga
- 213
It's only a 4 foot run from a plenum box. The other (2) 6 in runs coming out of the plenum box feeds the upstairs hall bathroom and the "toilet room" of the master bath. The run I was thinking of changing is a 8in duct connecting to that 5X8 boot. The plenum box if connected by a 10inch duct from the main air-handler plenum.
I caulked around the boot and grille last summer after reading how necessary it was.
02-10-2008, 10:10 PM #5
Banned
- Aug 2002
- 18,836
That's a small boot for an 8" duct,so it may make some difference.Is that grille noisey,if yes ,then some difference.
02-10-2008, 10:19 PM #6
- Aug 2007
- Atlanta, Ga
- 213
No, it's not noisy...but wanting to reduce the static pressure so more air will flow into the master bath. The bath has a 16-18 ft vaulted ceiling and the supply vent is located about 8 feet off the floor. The bath has a ceiling fan which helps...but my thinking was solely about increasing the volume of air.
02-11-2008, 02:39 AM #7
If you have a 5x8 boot fed by a 4' run of 8" duct, and it doesn't sound like a tornado has touched down in the room, there is far less air moving through that duct than it is capable of, lol.
Is there a damper at the ducts connection to the unit? It may be closed most of the way.If more government is the answer, then it's a really stupid question.
02-11-2008, 06:52 AM #8
- Aug 2007
- Atlanta, Ga
- 213
Not on that run, there are dampers on the other 2 runs coming out of that plenum box.
02-11-2008, 10:36 AM #9
- Aug 2007
- Atlanta, Ga
- 213
Looked a little closer...they installed the 8in duct into an 8X6 reducer into the boot...when I take the grille off, you can feel a change in velocity...I wonder why they did it that way?
Joe
02-11-2008, 11:49 AM #10
02-11-2008, 12:36 PM #11
- Aug 2007
- Atlanta, Ga
- 213
Where can I look for that grille?
Joe
02-11-2008, 01:11 PM #12
If you're lucky your local home center may have them. They can be identified by the curved blades that are movable...the fixed blade type, although curved, are less useful, IMO.
The curved blade models come in one or more directional "throws". Optimum "throw" from a supply register if it is near an inside wall (and mounted to the ceiling) is to "throw" the air stream toward an outside wall. The airstream should not point sharply down toward the floor...that will create uncomfortable drafts.
If you have high sidewall supply outlets, adjustable blade grills (not curved) are much better than cheap stamped steel two or three way grills. The damper inside the register can be used to aim the airstream slightly toward the ceiling, improving the throw of the register year round. Again, the object is to allow the air to become thoroughly mixed with the air in the room before it reaches the areas of the room where you normally occupy...oddly enough called the "occupied zone".
02-11-2008, 01:52 PM #13
- Aug 2007
- Atlanta, Ga
- 213
Here is another interesting tidbit...When I pulled the grille off, being 7ft high on a ladder, a could feel a cool breeze(granted not much) but it was there...with it being a little breezy outside...can it be entering from the exhaust on the roof and going thru the ductwork...and if so, how do you stop back-drafting from the exhaust flue?
Joe
