Thread: Sizing Question
    Jun 2006
    Sizing Question
    I have a system to put in, I have to follow an engineering plan, the plan states on a zone, First Company heat/cooling units with Lennox ac-14s. Anyway the plan calls for a MBXB30 but then specifies a Lennox 3-ton outside unit. On high the most cfm's I can move would be 1,000 so why would the plan specify a 3-ton outside unit.
    One or the other is a typo.
    Feb 2007
    Doesn't sound right. I'd be asking the same question. I would definitely voice your concern now. You know as well as I do that you'll be the one expected to perform miracles on this unit once it starts crapping out. Contact the engineer who speced out these components.
    Sep 2006
    Run
    My experience with First Company is with a botched hydronic design by the homeowner. Run!
