Thread: When does moisture condense
02-10-2008, 01:07 PM #1
- Feb 2007
- Bellingham, WA
- 115
I was wondering if there was a website or mathematical forumula to determine when moisture in the air will condense. For example, it the interior temperature is 70F and humidity is 40% then the moisture in the air will condense once the window's temperture falls below "X" F.
02-10-2008, 01:16 PM #2
There is a chart on this site that has what you want.
http://www.lamtec.com/dew-point-calculator.htm
02-10-2008, 04:20 PM #3
This is also a good site:
http://www.linric.com/webpsy.htm
To answer your example of 70 degrees/40% relative humidity, the window surface will begin condensing moisture once its interior surfaces fall below 44 degrees.
02-10-2008, 06:18 PM #4
- Jan 2007
- bowie md
- 116
Its called DEW POINT
02-10-2008, 07:35 PM #5
And it varies infinitely, depending on the exact temperature. That's why we measure the humidity as a RELATIVE number. When it gets to 100%, we change the name to water.
02-10-2008, 07:49 PM #6
- Feb 2004
- 2,597
Consult a psychometric chart.
