Results 1 to 10 of 10
    Oct 2007
    Washington, DC Metro Area
    Help determining SEER EER
    I am having the following Carrier equipment installed:
    Furnace - 58MCB040-1-08
    A/C - 24APA518
    Coil - CNPVP2417ATA
    Furnace - 58MXB080-F-1-20
    A/C - 24APA542
    Coil - CNPVP4221ATAABAA
    A/C - 24APA560
    Coil - CNPVP6024ATA
    I did not understand the ARI fill-in questions. http://www.hvac-talk.com/vbb/images/...s/confused.gif Any assistance is appreciated.
    Thanks in Advance.
    Are you sure you have the coil model numbers right.
    I can find cap coil ratings, not cnp.
    SW FL
    Thumbs up Catalog link
    Quote Originally Posted by civic4life2 View Post
    Furnace: 58MCB040-1-08 A/C: 24APA518 Coil:CNPVP2417ATA
    Furnace: 58MXB080-F120 A/C: 24APA542 Coil:CNPVP4221ATA A
    Furnace: 58MXB080-F120 A/C: 24APA560 Coil:CNPVP6024ATA
    Catalog for CARRIER 24APA5 products
    http://www.docs.hvacpartners.com/idc...24apa5-2pd.pdf
    Designer Dan
    Jun 2007
    The Twilight Zone
    A/C - 24APA518
    Coil - CNPVP2417ATA
    A/C - 24APA542
    A/C - 24APA560
    Coil - CNPVP6024ATA
    Thanks in Advance.
    Here's what I found from the ARI site, www.ARIDirectory.org :
    24APA518, CNPV*2417, 58MV(not C)B040:
    ARI# 1031793. 13.2 EER, 16 SEER
    24APA542, CNPV*4221, 58MV(not X)B080-20:
    ARI#1390282. 12.55 EER, 15 SEER
    No info on 24APA560.
    Good luck.
    Oct 2007
    Does the furnace make a difference?
    I used the attachment above, it was helpful, except that the furnace was not listed. gary_g came back with real numbers which was great. The issue may be that the furnace are comfort series and the a/c and coil are performance series.
    Thanks to all of you. garyg, dansw, and beenthere.
    DC Metro Area (MD)
    Sorry this doesn't have to do with your question of the SEER/EER numbers, but it is important.
    10 tons of cooling for our (MD/DC) area seems excessive. Did you make sure the contractor did a heat load calculation to determine proper sizing? My home is ~2500 sq. ft. and has 3.5 tons of cooling. I don't know what area you are in particularly though, so I can't envision the relative size of the homes.
    SW FL
    Question Size is all relative !
    Home is likely ( ?) 7,000 square feet ( ~ 3 x normal)
    or he likes indoor temperature at < 72' F in the summer.
    Designer Dan
    SW FL
    double
    Designer Dan
    Jun 2007
    The Twilight Zone
    I would contact Carrier directly and have them provide ARI#s for the system matches that are proposed.
    Best to you.
    Oct 2007
    I will contact carrier
    dan_sw is correct, its over 7,000 sqft finished on 4 levels. I will contact carrier as suggested by gary_g. I had not thought of that.
    The only response I had gotten from the contractor was that it was at least 14 each zone.
    Again thanks.
    We can close this thread.
