    condenser frost u, had to use emergency heat
    does any one know what is going on why condenser is frosted up? I had to use emergency heat?
    Nov 2007
    Washington State (on the Peninsula)
    Heat pump frosting is normal. It will defrost periodically. If you have Ice then there is a problem.
    Feb 2007
    Quote Originally Posted by AznR3DnecK View Post
    If you're talking about the outside unit of a heat pump, in the winter it's an evaporator, and that's normal, especially when the outside air temp is slightly above freezing. If you leave it on normal heat, and it doesn't defrost itself, then call a technician to look at it.
Comfortech365 Virtual Event
