Page 6 of 7 FirstFirst 1234567 LastLast
Results 66 to 78 of 81
  1. #66
    Nov 2001
    east kansas
    Quote Originally Posted by defaultech View Post
    always remember on aaon, lennox, and trane, to go back with factory motors. anything less will NOT last. it be intentional but its truth
    I agree.
  2. #67
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by AcDOCnTRAINIG View Post
    Why not in his opinion OEM motors are better, I don't see why thats not smart
    no, he did not say that O.E.M. parts are better
    lets go over what he said;
    AAON, LENNOX, and TRANE, when replacing motors on these systems, anything other than O.E.M. will not last!
    this was a very inaccurate statement, if the statement is true in your experiences
    than you are simply installing these parts improperly, or your not matching up parts properly!
  3. #68
    Jun 2007
    Central, FL
    Talking
    Quote Originally Posted by Airmechanical View Post
    You will continue thinking that way till one day you run into a problem like I did. See I thought just like you "AFTERMARKET" that was the purpose of this thread. I found out threw there tech support that Lennox have there condenser fan motors tied into a main control board and pressure switches,depending on stage and pressure it will decide to run motors. Those motors can cycle on and off up to 10x per cylce thats why they have stronger windings and bearings,also come with rain sheilds which keep the bearings well lubed and water out.There fan blades are pitched especialy balanced for a 1060 rpm motor(NOT 1075). The big picture is the whole thing is monitored from there control station, I mean everything amps(every motor), volts, pressures,stages,delta temp,static,even condensate line. Any thing goes wrong there on the phone with us. Its changed my way of thinking cause going aftermarket could of made me lost that account worth a WHOLE lot more than saving a few bucks on a motor! You see what I mean Burnnn
    WARNING:IF YOU DON'T KNOW THEN DON'T DO, SO THOSE WHO KNOW WHAT YOU DIDN'T KNOW DON'T END UP UNDOING WHAT YOU DID SO IT COULD GET DONE RIGHT!
  4. #69
    springdale, ar
    Hey, You may not see it to be smart but i can prove several documented cases where someone has pulled a condensor fan motor from the three brands I mentioned and they did not last. I had an aaon this summer that the customer matched motor perfectly and it still overheated. I ordered factory motor and it ran ok. many people make the mistake of replacing motors without thinking about dirty condensors raising the motor ambient temperature i know but factory motors will always last longer than aftermarket. Factory motors always fit right with proper lead length and/or proper plug. I cant stand to see motor leads and capacitors taped or zip tied to fan brackets. If you think thats ok then I see why you think my first post is not smart. hey, i know there are times the unit has to be fixed immediately and thats the only option but when possible keeping the unit original is always best.
  5. #70
    Nov 2001
    east kansas
    Don't sweet it, you had it right with your first post.
  6. #71
    Those aftermarket motors are great for holding you over until the OEM comes in.
  7. #72
    Dec 2006
    Middle Tennessee
    this is (probably) my last post about this subject
    since 1980 i have most likely replaced over 400 motors (cond and evaps)
    of the approximate 400 motors, maybe 20 of them were O.E.M., the only 2 non O.E.M. motor failure callbacks
    i can recall was when i replaced a rheem cond. motor with an aftermarket motor
    it stopped working the day after i installed it (opening on internal O.L.)
    but thats because there was no tag on the motor, it was an 875 rpm motor, i replaced it with a 1075 motor
    i should have been smart enough to use a pitch gauge on it, or called manufacturer to get info on the motor
    the other motor callback (thats a dirty word in the service trade) was on a carrier 80 ton chiller cond. motor
    the 460 volt single phase motor was marked by carrier as a 3/4 h.p. i noticed the replacement motor
    was physically smaller, but i installed it anyway, that motor after about 10 minutes of run time, cycled off on O.L.
    went back to the supply house and got a 1 h.p. motor it was phsically the same size as what i was replacing
    slammed the 1 h.p. motor in and i was golden
    not having to wait for carrier to get the motor in, and saving the customer a few hunded dollars
    and at the same time making the full amount of profit, with the exact same warranty, priceless!
    without doing a bunch of math that equates to only 8% of the motors i installed with O.E.M.
    lets review: full profit, save customer money, full warranty, i guess that makes me the aftermarket Mounty
  8. #73
    It works for you.
    Or did you replace the same 10 motors 400 times. Just kidding.
    On 460 single phase, I prefer the OEM motor.
  9. #74
    crossville
    Unhappy no it doesnt
    Quote Originally Posted by rambonole View Post
    1 hp not 1ph...has to be 3 ph
    I have install a many 1 horse power 460 volt 1 phase condenser fan motors
    all the mfg use them
    and most larger supplu houses carry them in stock
    they aint cheap tho
    If you cant cool it
    HEAT THE Hello out of it
  10. #75
    St Paul, minnesota
    [QUOTE=sodd81927;175684
  11. #76
    Jul 2009
    new york
    I have done the same and after markets work great! Guess I should tell my boss and all the customers aftermarkets don't work and we will be replacing them. Gezz some were but in 8 years ago and still no call backs. hmmmmmmmmmmmmmmmmm. Aftermarkets work great.Unless you get commission on OEM from the factory then OEM rock..
  12. #77
    New Jersey
    thats cool!
    no asterisk here, but as i learn, and from what i seen;
    460 volt fractional hp motors, in some cases the aftermarket motors can at times be better than OEM
    but for 460 volt motors of 1 hp and up the oem motors definately are the safe and sure bet
    “If I have seen further than others, it is by standing upon the shoulders of giants.” ~ Sir Isaac Newton
    I'm learning all the time, the tombstone will be my diploma!!!
    Did you ever stop to think, and forget to start again?
  13. #78
    May 2011
    Fort Worth, Texas
    Go with OEM!! You'll learn the hard way, if you go with a/m!
