Page 3 of 7 FirstFirst 1234567 LastLast
Results 27 to 39 of 81
  1. #27
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by supertek65 View Post
    we usually use a local motor company.
    single phase 460 volt 1 hp any rooftop guy has changed thousands of them.
    I changed 32 at one account.
    find a local armature ,or look under electric motor shop!
    you can save alot!!!!!!!!!!
    yap, i had 1 account with twenty five 30 ton old ass york packages
    6 condenser fans each 1/2 h.p. 460 volt single phase
    changed atleast 60 of them out in 3 years
  2. #28
    if you check 2 legs across 480 you will come up with 277, if that motor came off of a 3 phase 480 unit with single phase motors then they are 277 motors
  3. #29
    Oct 2007
    Austin Texas
    Do you have access to a Johnstone Supply? That is where I get all of my Lennox supplies.
    Nemo me impune lacessit.
    How much blood do I have to bathe in to get clean?
    Don't look down on anyone unless you're helping them up.
  4. #30
    Aug 2000
    Under my tree
    Huh? When did that start? They changed the fundamental laws of electricity?
    If you check across a 480V single phase circuit I would expect to see around 480V. If you checked either leg to ground you would get 277V. 277V is one 480V hot leg and a nuetral. 480V single phase is two 480V lines.
    Quote Originally Posted by air2spare View Post
    To much work with too little time!!!!
  5. #31
    Jan 2001
    chelmsford,ma.
    I,ve seen 277 single phase which would be one leg and neutral of 480 3 phase don't recall any 480 single phase
  6. #32
    yes sir, you are correct ( Im getting cut off from saturday night margaritas)
    Quote Originally Posted by absrbrtek View Post
  7. #33
    Jul 2003
    Orange County N.Y.
    ROOF RAT!!!!!!!!!!!!
    WE MUST HAVE A LOT IN COMMON
    Always a possibility.
    A co-worker gave me that name as a CB handle after he found out just how many commercial building roofs I've been on as a service technician. I don't go up on as many as I used to, I mainly can be found in mechanical rooms nowadays working on/in/around chiller plants.
    ...Ron
    Roof Rat
  8. #34
    I Once Interviewed For A Job And Did Not Get It.
    He Said I Was Only A Roof Top Guy!
    I Got The Nik Name #1 Roof Top Guy
    Used To Think It Was Bad, There Are Not Alot Of Great Rooftop Guys.
    Like You I Get To Do Alot More Chillers Now.
    I Welcome 8 Hour Rooftop Inspections!
    true knowledge exists in knowing that you know nothing.
  9. #35
    Aug 2005
    Tampa
    Quote Originally Posted by dgruber View Post
    Carrier and Trane both have a 1ph 460 volt motor. I have replaced that same Lennox motor.
    Yes, make sure you replace the capacitor and also the Rain Shield, if it has one existing!
    Some of these motors have a certain frame size that will indicate shaft size!
    Some have 1/2" shaft some have 5/8" shaft.
    Johnstone Supply is pretty good with OEM replacements. They can UPS, if you pay by credit card, should you not have a account. http://www.johnstonesupply.com/corp/Default.aspx
    AO Smith used to make a motor that included a rain shield, that was very dependable and versatile, with a 5/8" shaft, but you had to remove the electrical pecker head on some installs.
    Fully agree with This. I use so many 1hp 1phase 460v condensor motors, I carry one on my truck, with a rain shield.
    You want me to do what, with that thing!!!!!!
  10. #36
    Jul 2003
    Orange County N.Y.
    I know what you mean, I like mid spring inspections myself. I was in a refrigeration and air conditioning shop before I came to work for the manufacturer. No formal schooling, though the man that taught me graduated from Delhi here in NY, he took the refrigeration courses. At the end of my stay at that company I was doing most of the rack refrigeration and ice machine calls that came in. Now it's mostly chiller work with some roof top equipment thrown in when they need me. Very rarely do I do any refrigeration work anymore. I did have one ice machine that was used for comfort cooling, had around fifty plates that were 4'W x 8'L, I miss working on that one. The last bit of refer work I did was on a hospital morgue, no one could find a leak on it. Took me about 10 minutes to find it.
    Ever go to that riverboat museum out in KC? Interesting, I thought.
    ...Ron
    Roof Rat
  11. #37
    Nov 2005
    Shreveport, Louisiana
    Quote Originally Posted by rambonole View Post
    1 hp not 1ph...has to be 3 ph
    Why does a 460 volt condensor motor have to be 3 phase?
  12. #38
    Quote Originally Posted by rscamaro View Post
    ...Ron
    the steam boat arabia?
    I have never been but heard it is great!
  13. #39
    Jul 2003
    Orange County N.Y.
    Yep, that's the one. I was out there visiting my wifes family a few years ago and had the oportunity to go. It was dug up by some HVAC guys, probably what keeps it in my mind when the KC subject comes up. I think that The Discovery Channel did a program on it, interesting, what with all of the antiques that they have. I'm not into old stuff like that unless it has something to do with power transmission but the craftsmanship is incredible.
    ...Ron
    Roof Rat
