Results 14 to 16 of 16
    oregon
    Quote Originally Posted by JMSTA View Post
    The guy had just started his HVAC business had been in business for about 6 months. He had been working for a company that did commercial installs for years. He had some pretty good references and beyond the references he offered I called around to the local plumbing and heating distributors and asked about him all came back pretty positive. Turns out he ended up getting a job with company in a different state and effectively quit on my job. For a while he was making an attempt to get someone local to finish up his work but it never happened.
    Not good.
    The thermostat you listed, I could not get set up data off the net. Perhaps one of the other pros here could help you with the stats. I would recommend one of the ones I listed before, so you have a matched system. With the xli heat pumps your ten year parts warranty on them would also cover the thermostats as well as the parts on the furnace. ( trane stats ,like the tcont803)
    Genius = The guy who can do anything...except make a living!
    Where do you live?
    Go to the distributor that he purchased the equipment through they are responsible for his 2 year dealer obligation.
    Mar 2006
    The South
    JMSTA
    any update on your problems?
    Obviously they are not as serious since you found out that your backup gas furnaces were the correct var speed XV models. I am just surprised that you have been living with this mess for so long.
    IMO
