    Mixing valve location
    Should a mixing valve be situated before or after a circular, and why?
    Grottoes VA
    You need to pull the water through the mixing valve. That way it can pull water through both the cold and hot sides to be able to mix the water.
    Massachusetts
    Well it all depends on which circulator you're talking about. Normally there's at least two and more often than not several in a system. So........some are before and some are after.
