    The Gray Northwest
    Humidifier Hammer
    Ive got a humidifier system that feeds 2 air handlers that serve electronic equipment rooms. It's a glorified pressure whasher with the nozzles in the ducting. On a call for moisture, the nozzle line solenoids slam open with 1000psi behind them and then slam shut when not needed. The building occupants are complaining about the noise (mechanical room has common wall to offices) and the Unistrut is ripping itself off the wall from the water hammer. The manufacturer was no help. Does anyone make piping clamps that dampen vibration and hammer?
    Central Indiana
    Talking Humidifier hammer
    Quote Originally Posted by big johnson View Post
    I would change out the nozzle solenoids and put in valves. Motors for these should be say, 30 sec. This will completely eliminate the water hammer.
    Thanks. Mike
    Dec 2003
    Northern VA
    If I had a Hammer...
    I'd put in ASCO Red Hat Slow opening solenoids and be done with it.
    Should'a been spec'd. in the first place.
    "Iron sharpeneth iron..."
    Dec 2003
    Northern VA
    That would be...
    The ASCO #8221 Slow closing valve.
    See their site.
    And Good Luck.
