A. Edit out the prices, no prices allowed by site rules. If you don't, a mod will.
B. With out the mod numbers of the Amana, can't make a good comparison.
Hello, I have a 31 year old whirlpool forced hot air furnace I am looking to replace. It works well, but the bills have been high. I have found 2 reputable installers and need held in decyphering the two quotes. I am located in Northern CT and want an efficient furnace as I plan to be in this house for the next 30 years.
Quote 1:
Trane TUH2B080A9V3VAA --- Is this an XV95?
Condensate Pump
trane tcont803asa1aa thermostat
Liner for Chimney
All permits pulled
10 year parts and labor warranty
Installation
Quote 2:
Amana 95% 90,000 BTU 2 stage - No model number provided (Believe it to be AMH95)
Condensate Pump
PVC Pipe to direct vent
Digital Thermostat
Full lifetime unit replacement if the heat exchanger ever fails
2 year 100% money back guaranty for any reason
10 year no lemon heat exchanger guarantee
All permits pulled
Both installers have great BBB records... The prices are equivalent
Thoughts?
Thanks in advance for the help.
The Trane Furnace comes with a warranty on the heat exchanger. And the TCON 803 is a touchscreen thermostat. Where as the Amana just says digital thermostat.
I work for a Trane dealer in NC and as far as I'm concerned, Trane is a better brand equipment. I say this because your more likely to get service techs that have been to Trane specific schooling. I have.
But as for Amana, I don't know too much about them. I have worked on them and the Trane seems to be more Service Tech friendly.
Thanks for your info. I have heard mixed information on the Goodman/Amana and good info on the American Standard/Trane. As far as the warranties, I like the idea of a lifetime warranty on the heat exchanger.
Do you know for the Trane, if both primary and secondary heat exchangers are stainless steel?
I went with the Trane, and a highly recommended installer. Planned installation is Friday!
Also, the dealer informed me that he should have quoted the 100K BTU based on his calculations and that he'd sell me that one for the same price. He also convinced me to get the Trane Humidifier as well.
Thanks again for your assistance
Let us know how you like it in a couple weeks.
Good move, you weren't comparing like products. The XV95 has the variable speed blower, the AMH doesn't. Also the AMH can't use a 2 stage thermostat so you wouldn't have the benefit of long run cycles on low in bitter weather. The XV95 is a nice furnace.
Trane is a 80% furnace not two stage and Amana is a 95% effecient two stage.
Say what?
TUH is a 95% furnace
2 indicates 2 stage
Only thing I'd do is ditch the 803 and put on a Vision Pro IAQ and hook up dehumidify on demand.
Seldom is the bald one incorrect.
