Results 14 to 22 of 22
    I believe Belimo makes any and all types of damper and valve motors in all voltage ranges.
    Dec 2003
    Middle of Florida
    Ruskin and Honeywell have both 120V and 24V.
    Usually the bigger the damper the more likely you are to see 120V spec's
    If common sense is so common how come so few of us have it!
    arlington, tx
    why is it that electricians dont know anything about voltage less than 120
    New Mexico
    Quote Originally Posted by JRINJAX View Post
    I have a stepdown transformer at my shop that I feed backward to test run 460 volt electronic cabinet coolers.
    Not a problem if it's big enough. This one was 40va.
    I should have played the g'tar on the MTV. MK
    You can be anything you want......As long as you don't suck at it.
    SMW Lu49
    Southern, CA
    For the same reason I'd guess that most HVAC guys couldn't answer off the top of their heads, how many of a particular size wire can, by code, be run through a given size of conduit? It's something that's usually not needed for us to know to earn our pay. I'd like to learn more about their buis, but is unlikely as I haven't finished with this one. And my earplugs are slippin already.
    arlington, tx
    Quote Originally Posted by Coolmaniac View Post
    ya but its still electricity
    May 2008
    Jax Fl.
    The "fill" percentage of the conduit is dependent on how much current the conductors are sized for compared to how much they are carrying and the insulation type of the wire inside of it.
    You can never be more than 80% normally.
    I was an Electrician before I made HVAC my Profession...
    arlington, tx
    i have alot of respect for guys that dont limit themselves to one trade it makes you more valuable...im gettin my plumbing license next month then preparing for electrical to me its all the same thing
    May 2008
    Jax Fl.
    Thanks,
    The electrical comes in handy sometimes, but it is hard to stay current with the code changes if you don't do it every day.
    Good luck on the plumbing.
